Server Version#: latest, plexpass
Restarting the server docker fails. The log indicates that the server seems to be in a loop saying “Starting Plex media Server.”. I have left this 30mins or more!!! I have also tried restarting unraid. This makes no difference!!
“[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] 40-plex-first-run: executing…
[cont-init.d] 40-plex-first-run: exited 0.
[cont-init.d] 50-plex-update: executing…
[cont-init.d] 50-plex-update: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
Starting Plex Media Server.
Starting Plex Media Server.”
I have the same exact issue - Unraid 6.7.2 - plexinc/pms-docker - latest . The logs even look the same.
[services.d] done.
(repeats)
I followed the corrupt database article referenced- and chose to delete the library.db (all dbs). When I restarted Plex - it rebuilt the dbs, but had the same loop.
I then un-installed the docker.
Deleted the appdata folder for Plex and reinstalled. Same loop.
In my case it corrupted several times even after a fresh install. Reverting to 6.6.7 with a working db fixed it. Took two weeks trying each version. Tested this about 20 times with the various solutions on the Unraid forums. This isn’t probably an issue that is to be fixed on Plex side. Many cases of it on the Unraid forum. Happens with Radarr and Sonarr too. Dockers with sqlite dbs.
As for the loop, this is what worked for me. Just remove all the db files and start only with the library.db or hunt and delete the two blob.db files, it should start. I could replicate this with a recovered db and a non-matching blob.db. Deleting the blob.db always broke the loop for me.
