Stitching DVDs together- file size issues
So, I’ve ripped some DVDs. Some movies are old school and span across two DVDs. Others have been ripped in chapters.
I was considering using a video package to stitch them together, however the file sizes seem ridiculous and I’m sure it must be me.
For example, there’s four files that total 10gb, but when I go to render the video, the final video in HD (I am assuming the original rips are HD) is a total of over 30gb.
I’ve tried on both Premier and Movie Maker.
What am I doing wrong?
DVD doesn’t have HD.
DVD uses MPEG2 as video codec, which is way less efficient than AVC or even HEVC.
I propose this MO:
  1. rip the DVDs without changing the codec or resolution, using Makemkv (Google it)
  2. append the parts to get a complete movie, following this HowTo [HowTo]: joining multi-part movies files with MKVtoolnix GUI
  3. Employ Handbrake to convert the MPEG2 codec to AVC, to remove the black borders and to remove the interlacing if necessary.
