If you rather don’t want to post those logs, keep in mind that there are by default 6 log files to look into: Plex Media Server.log + Plex Media Server.1.log – Plex Media Server.5.log
If you trigger a library scan during maintenance, the relevant log lines might be flushed out already.
In some extreme cases, you’ll have to tell Plex to increase the total number of log files (by setting a hidden server preference) to catch those lines.
It might also be worth considering to fetch the log files immediately after the cutoff time of the maintenance period. If you are not at home around this time, you can fetch them per remote access as well.
