Strange issue causing Plex to “stall” for several minutes randomly
Server Version#: 1.28.1.6041
I’m having a very weird issue with Plex. Randomly (every 15-30mins or so) it “stalls” for a few minutes and then comes back on its own. Server is down for this period. I cannot find anything in the logs which suggest an issue. I’ve done a full server swap and it still happens.
I’ve done a database optimize, bundles, trash etc.
Docker logs don’t show anything weird
Can you provide some more info please about the operational environment?
Also, would it be possible to get a set of DEBUG logs which capture this happening?
If you can capture the logs right after a stall and then let me know when the stall began, I will look at the logs for a correlation.
Happened at 21:03 Hastebin: Send and Save Text or Code Snippets for Free | Toptal®
I’m using a Linux server docker container on Ubuntu 22.04
@ChuckPa
Thanks.
This is a networking issue.
Aug 08, 2022 21:03:23.273 [0x7f4cab5e0b00] DEBUG - [EventSourceClient/pubsub/184.105.148.114:443] MyPlex: We appear to have regained Internet connectivity.
Please notice,
Aug 08, 2022 21:03:12.346 [0x7f4cab603b00] DEBUG - Auth: authenticated user 22935660 as Naiko83
Aug 08, 2022 21:03:12.347 [0x7f4ca54d7b00] DEBUG - Request: [172.22.0.2:41798 (WAN)] GET /media/providers (137 live) #6edd TLS GZIP Signed-in Token (Naiko83)
Aug 08, 2022 21:03:12.352 [0x7f4cab603b00] DEBUG - Completed: [172.22.0.2:41798] 200 GET /media/providers (137 live) TLS GZIP 4ms 6055 bytes
Aug 08, 2022 21:03:22.617 [0x7f4cab5e0b00] DEBUG - [EventSourceClient/pubsub/184.105.148.114:443] Resolving 184.105.148.114 port 443
Aug 08, 2022 21:03:22.623 [0x7f4cab5e0b00] DEBUG - [EventSourceClient/pubsub/184.105.148.114:443] Resolved 184.105.148.114 to 184.105.148.114:443
Aug 08, 2022 21:03:22.705 [0x7f4cab5e0b00] DEBUG - [EventSourceClient/pubsub/184.105.148.114:443] Connected in 82 ms.
Aug 08, 2022 21:03:22.708 [0x7f4cab5e0b00] DEBUG - [EventSourceClient/pubsub/184.105.148.114:443] Wrote data, reading reply.
Aug 08, 2022 21:03:23.273 [0x7f4cab5e0b00] DEBUG - [EventSourceClient/pubsub/184.105.148.114:443] Read HTTP reply header.
Aug 08, 2022 21:03:23.960 [0x7f4cab5e0b00] DEBUG - [EventSourceClient/pubsub/184.105.148.114:443] MyPlex: async reachability check - current mapped state: 'Mapped - Not Published (Not Reachable)'.
Aug 08, 2022 21:03:23.960 [0x7f4cab5e0b00] DEBUG - [EventSourceClient/pubsub/184.105.148.114:443] MyPlex: Requesting reachability check.
Aug 08, 2022 21:03:23.961 [0x7f4cab5e0b00] DEBUG - [EventSourceClient/pubsub/184.105.148.114:443/HCl#56c] HTTP requesting PUT https://plex.tv/api/servers/b0b7a2a4f954796ac9f049d5de389c2ebe00e999/connectivity?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx&asyncIdentifier=939781c5-65d5-4388-9118-9ac3e0d84768
Aug 08, 2022 21:03:24.129 [0x7f4cab30cb00] DEBUG - [HttpClient/HCl#56c] HTTP/2.0 (0.2s) 200 response from PUT https://plex.tv/api/servers/b0b7a2a4f954796ac9f049d5de389c2ebe00e999/connectivity?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx&asyncIdentifier=939781c5-65d5-4388-9118-9ac3e0d84768 (reused)
Aug 08, 2022 21:03:24.132 [0x7f4cab5e0b00] DEBUG - [EventSourceClient/pubsub/184.105.148.114:443]
This will cause all connections to reset. Players will have to time out and recycle the connection to recover/continue
