Strange remote-access buffering/speed issue?
Server Version#: 1.25.0.5282-2edd3c44d (Ubuntu Package)
Player Version#: Web, Win10, Android
I’m having a very strange issue with my Plex server and endless buffering. I’m at a loss of what else to check. Playback is trying to view DVD quality content.
Plex Server: Ubuntu Server VM, 4 cores, 8GB RAM, 1Gbps e1000
Hypervisor: CentOS 7, Intel(R) Xeon(R) E-2176G CPU @ 3.70GHz, 64GB RAM, 2x1Gbps bonded NIC
Router: pfSense, AMD RX-427BB, 16GB RAM, i350-T4 NICISP: 1000x50 (actual 700x25 to 950x53)
Playback content: DVD quality, ~9Mbps, 480p
Player: Firefox browser Linux (similar issue appears to affect Win10 app, Android app)
Boot OS and Plex directory are on SSD-backed RAID1 storage
Media library directory is on HDD-backed RAID5 storage
CPU utilization on the VM is very low (<20% during playback with or without transcoding)
RAM utilization on the hypervisor is very low (<5% during playback with or without transcoding)
CPU utilization on the hypervisor is low (<60% peak, several VMs running)
RAM utilization on the hypervisor is as expected (<80% peak, several VMs running)
Network utilization in/out of hypervisor is low, ~100Mbps in, <10Mbps out)
Test Cases - where it gets funky:
LAN playback is fine, multiple streams at once. No issues.
Remote playback (internet) → maybe transcode to 700Kbps without buffering (if that)
Remote playback (OpenVPN on pfSense different interface but same router where Plex is) → can’t even do 700Kbps without buffering
Remote playback (Firefox SOCKS5 proxy via SSH tunnel Linux box on same subnet as Plex server) → Works great, as good as LAN, easy 10Mbps throughput or any transcode quality, fast, no buffering
This seems very confusing to me. Clearly my server running Plex can handle the streaming because it works locally and when I use a SSH tunnel/SOCKS5 proxy. Clearly my ISP upload can handle the bitrates because it works fine if I use a SSH tunnel/SOCKS5 proxy back to the same subnet Plex is on.
Why can it not handle more than a trickle of bandwidth when I am using remote-playback “normally” or thru OpenVPN?
Hi, I have the same issue, I am not limited in any way by hardware or internet, yet PMS can not go over 45 Mbps upload. Here is my post:
I recommend doing a base networking speed test between the two points.
  1. On the Linux machine
  • Install iperf3
  • Start the iperf3 server in a command line shell with iperf3 -s
  • Open and port forward port 5201 (TCP/UDP) from the modem router to the Linux machine
  1. In the client
  • Install iperf3
  • Invoke the test using
    • iperf3 -c ip.addr.of.server
  • Let it finish
    • iperf3 -c ip.addr.of.server -R
You will now have definitive point-to-point network performance.
It will show -
  • Throughput
  • Number of retries (which will impact Plex’s streaming)
So it gets even more strange doing that.
iperf3 from my hypervisor thru the Internet to my parents house – around 35-40Mbps (in line with my upload speeds)
iperf3 from Plex VM to my hypervisor – 950Mbps
iperf3 from Plex VM to my laptop over WiFi LAN – 350-400Mbps (maxes out my WiFi)
iperf3 from Plex VM thru the Internet to my parents house – around 750-800Kbps
So I’m still stuck with this bizarre issue. I don’t think it could be with the VM or hypervisor because it can max out my LAN. But I don’t think it could be the Internet because I can max that out with a different LAN host.
