Strange web intrface issue
I have strange problem when I select my user id and click switch users and select my id again or after I close the browser window and select my user id. The activity icon will show two objects under it. If you click on one of the dashboard links it will error out and not work at all. I can sign out and sign back in again and select my user id then everything is ok. The only thing I can remember doing is I added a audio book plugin (https://github.com/macr0dev/Audiobooks.bundle).
Would adding this plugin cause the behavior?
Hi there, thanks for the report. I’m having trouble reproducing this myself. Could you enable logging as described here and send them over after reproducing the issue?
I added the log files you’ve requested.
Browser Console Log.txt (27.9 KB)
Plex Log.txt (64.5 KB)
I also forgot to add that I’m on the Beta channel with version 1.15.1.710
I just updated to version 1.15.1.780 and I see that same problem. I’ve tested Chrome 72 and for kicks I even tried IE11 and found the same issue.
I’ve recently updated to Version 1.15.5.994 and tried Firefox 66.0.3 (64-bit) and 74.0.3729.131 (64-bit) and the problem has went away.
