Server Version#: Version 1.16.2.1321
fiber in - fiber modem / wifi router
/ ethernet cable to another home / wifi router
So i have my media server in the main home with the fiber connection. That modem is a full gateway with switch and router. I have an underground ethernet cable going to the other home on the property. That home has an asus dark knight router. When i connect to that wifi, plex is only letting me stream 1 minute at a time. What do i need to do to get it let me stream.
Is it because i am running express vpn on most of my devices?
It may depend on the app you’re using. Some of the mobile apps are not free, unless you have a Plex Pass. If you’re using one of the non-free apps, but haven’t paid for it, they may limit you to one-minute streams.
Plex can also serve as a DLNA server, but I don’t know too much about that. I think it’s a bit limited. There’s info about it on the page I linked earlier.
The mobile apps (Android, iOS, and Windows) are free to install but run in a trial mode, which includes playback limited to 1 minute. You need to activate the app to remove this limitation. The app can be activated with either making an in-app activation purchase through the app store or by logging into the app using a Plex account that has a Plex Pass.
Only these mobile apps have this requirement. All other Plex clients are free and have no playback limitations.
