Hi, i’ve been looking into how all the streaming brain stuff works with Plex . i get it , it makes sense in the logs and i understand the decisions its makes … but is it too conservative with allowing what can be direct played ?
Here’s my scenario. i’m using a Raspberry PI that has about 150 MB of cache . now i have about 20 Mbps upload speed., the file i’m playing has an average bitrate of 10 Mbps . i understand that movies peak and go way above that number . plex logs show at some stages it may even jump to 46 Mbps
Now i’ve watched about 50 movies with this setup , any movie i have that has an average bitrate over 12000 Kbps i transcode as i know that with the peaks in movies up upload may struggle . but otherwise that setup has served me well with my movies
Now i recently messed with the upload setting, setting it to 25 mbps . just so that i would saturate the upload as i know it uses 80% ( i know i shouldn’t , but i wanted to see what it was capable of )
Now with this new setup that movie i mentioned first with 10mbps average will transcode . In the logs it shows as
Streaming Resource: Bandwidth exceeded: 20584 kbps > 20000 kbps
so that’s why it trancodes . i’m guessing the 20584 number is made up out of a number of factors , buffer, network etc etc . i get it. although i played with the buffer sizes on my raspberry pi and i could see in the logs that they were higher, but the 20584 number didn’t change… not sure on that one.
I’m pretty confident however that that movie using my old setup would direct play without a hitch using the 150 MB cache for when things got a little crazy., maybe i’m wrong on that , but as i said i’ve played 50 + movies and its been fine . so going back to my previous question… is it too conservative //
This is also more of a request than a question. or maybe a bit of both . but lets say i start watching a movie that uses 18 out of the 20 mbps upload . if someone else starts a show or a movie now it’ll automatically transcode that down to 2 mbps for that person… would it be possible sometime in the future to have it share the connection between the people ? so my stream would dynamically change to 9 mbps and they would also get 9. and if a 3rd joins in , it would again scale between 3 so it would be 6 mbps each … that would be pretty great and very versatile.
