Server Version#: 1.24.3.5033
Player Version#: 8.23.1.28053
Bravia Android Kernel Version#: 4.9.125
Sony Model: XBR-65X800G
Sony_Bravia_Log.txt (958.6 KB)
Plex Media Server.log (364.3 KB)
For the past few months, I have been having issues with Plex on my Sony Bravia which is our main TV. Chromecast, iOS, Windows, and my Android cell phone have no issues either connected to LAN or Remote, it plays almost instantly with the same show that just sits frozen. The buffer bar even shows it’s loaded but it won’t play. Netflix, Hulu, and HBO Max all play fine as well. I have tried the following:
Restart TV manually by going to Settings, and clicking restart. This typically resolves the issues for that single movie or episode as long as I don’t turn off the TV.
I have also cleared all data from the Plex app, uninstalled, deleted it from PMS, and reinstalled it. No change with this.
I tried disabling secure connections on both PMS and the App with no change.
I was able to capture the exact thing I was talking about above in the Sony_Bravia_Log.txt. I think I can only use network logs for that app. I was able to restart the TV, open Plex, start network logging, open a show that wouldn’t play before and it played fine and almost instantly. I then turned the TV off and back on, and it wouldn’t play the show anymore.
If it helps, I am running PMS on RHEL8, both RHEL8 and PMS are up-to-date.
I’m not sure what else to do at this point any help would be greatly appreciated.
