Plex on Sony Bravia works flawlessly until it gets stuck and can't even start it again
Server Version#: 4.140.0
Player Version#: 10.24.0.2257
I’m using Plex now for a while and am amazed, so my database got quite huge (100+TB). However, a while ago Plex stopped working on my Sony Bravia while perfectly working over web interface or iOS devices. It eventually started to work again after i force closed all apps (including Plex) on the TV and deleted their cache.
Now it happened again, but none of the above worked, I even uninstalled and installed the Plex app again, but still not working. I can’t see anything from the logs beside:
MovieDB Couldn't fetch providers. Result: Error (null)
I moved to a remote server for Plex to have access from everywhere and my home connection doesn’t guarantee a good enough upstream. Also I managed to change the standard port to 443 to route it through Cloudflare which resulted in a much better viewing experience without any buffering, especially for 4K content.
Any help will be much appreciated!
2024-12-06_Plex_Bravia_logging.txt (137.7 KB)
In the log I edited out the IP addresses of my remote server for obvious reasons.
