strm files (question about)
Could someone tell me why I can not read any .strm files while this is not a problem with xbmc???
I have a folder containing a file.strm for each tv live channel pointing to my HDHomeRun tuner, with inside the following code:
hdhomerun://1220B6D0-1/tuner1?channel=auto8c:306&program=1 for example
This way, a can watch any channel with XBMC by simply adding the folder as a source!
Thanks,
JonKP
Yes I have the Same Problem.
I make a Reference QT File with this
<?xml version="1.0"?>
<?quicktime type="application/x-quicktime-media-link"?>
But the Same Problems.
Does exist another Method to stream?
