Server Version#: 1.16.6.1592
Player Version#: 3.108.2
Naturally everything worked before I backed up and rebuilt my server. Now for the past month or so I have that status on my activity icon and I can’t get rid of it. Cancelling the refresh doesn’t do anything, nor does deleting the tuner (it actually shows back up after a while). Odd and annoying.
I have exactly the same issue, I’ve tried the following:
Stop Plex
Disconnect tuner, restart plex
Repair plex
uninstall plex
Stopping the plex tuner service
All without success.
Happily I also have Emby so I still have a DVR.
Hey ho
This isn’t critical to me either as I’m using Channels DVR, and I’m quite happy with it. Unfortunately my family doesn’t like it because they’re used to tuning by punching numbers, a feature that I’m hoping Plex DVR or Channels DVR will soon figure out.
Such responsive support. Is there a better way to contact support?
was there ever a response with a resolution on this same issue? I have the same issue
No. No communications from anyone representing Plex.
I am also suddenly having this problem
Hopefully you can get some help. On my server this resolved itself some weeks ago.
