Studdering with mpeg2ts playback after skip
I’m watching my DVR recordings and am experiencing studdering after skipping forward. My setup is an nvidia shield as PMS + client, and my media library is on a NAS. Everything is hard wired with >30-50 MB/s read / write between the devices.
The shield reports that it is direct playing the video and audio, while transcoding because “container (mpeg2ts) is not supported”. The transcoder is running to play back these files as i see the temp directory filled.
Below are the logs from the client and server which provides detail. Would love to get anyone’s thoughts.
Client logs
08-17 14:50:52.693  i: Fetching [method:GET] https://192.168.1.130:32400/:/timeline?bandwidth=5687&bufferedTime=21&containerKey=%2FplayQueues%2F77&duration=6032000&guid=com.gracenote.tms%3A%2F%2Fmovie%2FMV000420020000&key=%2Flibrary%2Fmetadata%2F2040&machineIdentifier=d8793166988cd8f6a74e18b775f871de3ebd28c5&playQueueItemID=389&ratingKey=2040&state=playing&time=4658954&token=...7NNH&X-Plex-Client-Identifier=8f64587ec8a41fd3-com-plexapp-android&X-Plex-Token=...7NNH
08-17 14:50:59.985  i: [pms] /127.0.0.1:47585 - GET /proxy
08-17 14:50:59.986  i: [Proxy] Request received: https://192.168.1.130:32400/video/:/transcode/universal/session/8f64587ec8a41fd3-com-plexapp-android/base/01561.ts
08-17 14:51:00.018  i: [Proxy] Response: 200
08-17 14:51:00.442  i: [AudioManagerCapabilitiesSource] Device added (SHIELD Android TV, 13)
08-17 14:51:00.442  i: [AudioCapabilitiesSource] Reporting capabilities changed
08-17 14:51:00.503  i: [pms] /127.0.0.1:47589 - GET /proxy
08-17 14:51:00.503  i: [Proxy] Request received: https://192.168.1.130:32400/video/:/transcode/universal/session/8f64587ec8a41fd3-com-plexapp-android/base/01562.ts
08-17 14:51:00.516  i: [Proxy] Response: 200
08-17 14:51:00.658  i: [ExoVideoPlayer] Seeking to 4696872ms
08-17 14:51:00.661  i: [Exo1VideoPlayer] Player state changed: 3, Restarting: true
08-17 14:51:00.712  i: [pms] /127.0.0.1:47590 - GET /proxy
08-17 14:51:00.712  i: [Proxy] Request received: https://192.168.1.130:32400/video/:/transcode/universal/session/8f64587ec8a41fd3-com-plexapp-android/base/01565.ts
08-17 14:51:00.794  i: [Proxy] Response: 200
08-17 14:51:00.813  e: An exception occurred: java.io.IOException: Connection reset by peer
08-17 14:51:00.814  e: Stacktrace: java.io.IOException: Connection reset by peer
	at sun.nio.ch.FileDispatcherImpl.write0(Native Method)
	at sun.nio.ch.SocketDispatcher.write(SocketDispatcher.java:53)
	at sun.nio.ch.IOUtil.writeFromNativeBuffer(IOUtil.java:93)
	at sun.nio.ch.IOUtil.write(IOUtil.java:51)
	at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:490)
	at org.jboss.netty.channel.a.a.x.a(SourceFile:240)
	at org.jboss.netty.channel.a.a.q.d(SourceFile:472)
	at org.jboss.netty.channel.a.a.q.a(SourceFile:390)
	at org.jboss.netty.channel.a.a.k.b(SourceFile:137)
	at org.jboss.netty.channel.a.a.k.a(SourceFile:76)
	at org.jboss.netty.channel.ae.b(SourceFile:771)
	at org.jboss.netty.c.a.c.b.a(SourceFile:68)
	at org.jboss.netty.channel.ae.b(SourceFile:776)
	at org.jboss.netty.channel.z.a(SourceFile:632)
	at org.jboss.netty.c.c.d.b(SourceFile:262)
	at org.jboss.netty.c.c.d.a(SourceFile:125)
	at org.jboss.netty.channel.z.b(SourceFile:611)
	at org.jboss.netty.channel.z.b(SourceFile:578)
	at org.jboss.netty.channel.a.a(SourceFile:251)
	at com.plexapp.plex.net.pms.u.a(SourceFile:190)
	at com.plexapp.plex.net.pms.u.a(SourceFile:103)
	at com.plexapp.plex.net.pms.r.a(SourceFile:78)
	at org.jboss.netty.channel.aw.b(SourceFile:80)
	at org.jboss.netty.channel.ae.a(SourceFile:783)
	at org.jboss.netty.c.c.d.b(SourceFile:149)
	at org.jboss.netty.c.a.b.h.a(SourceFile:116)
	at org.jboss.netty.channel.z.a(SourceFile:302)
	at org.jboss.netty.c.a.d.b.a(SourceFile:527)
	at org.jboss.netty.c.a.d.b.a(SourceFile:506)
	at org.jboss.netty.c.a.d.b.a(SourceFile:443)
	at org.jboss.netty.channel.z.a(SourceFile:274)
	at org.jboss.netty.channel.z.a(SourceFile:261)
	at org.jboss.netty.channel.a.a.q.b(SourceFile:351)
	at org.jboss.netty.channel.a.a.q.a(SourceFile:282)
	at org.jboss.netty.channel.a.a.q.run(SourceFile:202)
	at org.jboss.netty.e.i.run(SourceFile:108)
	at org.jboss.netty.e.a.ab$1.run(SourceFile:44)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1133)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:607)
	at java.lang.Thread.run(Thread.java:761)
08-17 14:51:00.816  w: [pms] Client closed the channel
08-17 14:51:02.284  i: [ExoVideoPlayer] Seeking to 4726872ms
08-17 14:51:02.693  i: Fetching [method:GET] https://192.168.1.130:32400/:/timeline?bandwidth=99120&bufferedTime=0&containerKey=%2FplayQueues%2F77&duration=6032000&guid=com.gracenote.tms%3A%2F%2Fmovie%2FMV000420020000&key=%2Flibrary%2Fmetadata%2F2040&machineIdentifier=d8793166988cd8f6a74e18b775f871de3ebd28c5&playQueueItemID=389&ratingKey=2040&state=playing&time=4726872&token=...7NNH&X-Plex-Client-Identifier=8f64587ec8a41fd3-com-plexapp-android&X-Plex-Token=...7NNH
08-17 14:51:02.776  i: [pms] /127.0.0.1:47595 - GET /proxy
08-17 14:51:02.777  i: [Proxy] Request received: https://192.168.1.130:32400/video/:/transcode/universal/session/8f64587ec8a41fd3-com-plexapp-android/base/01575.ts
08-17 14:51:02.865  i: [Proxy] Response: 200
08-17 14:51:02.875  e: An exception occurred: java.io.IOException: Broken pipe
Server logs
Aug 17, 2017 14:50:50.648 [3093] DEBUG - Completed: [127.0.0.1:55369] 206 PUT /video/:/transcode/session/8f64587ec8a41fd3-com-plexapp-android/747a2993-d78f-4901-b937-2b42a46db8ab/progress?progress=78.6&size=-22&remaining=1903&speed=0.5 (10 live) 1ms 326 bytes
Aug 17, 2017 14:50:52.471 [3094] DEBUG - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Aug 17, 2017 14:50:52.472 [3094] DEBUG - Auth: Came in with the master token, authorization succeeded.
Aug 17, 2017 14:50:52.473 [5126] DEBUG - Request: [127.0.0.1:55370 (Loopback)] PUT /video/:/transcode/session/8f64587ec8a41fd3-com-plexapp-android/747a2993-d78f-4901-b937-2b42a46db8ab/progress?progress=78.6&size=-22&remaining=2567&speed=0.5 (11 live) Signed-in Token (abarbaccia)
Aug 17, 2017 14:50:52.474 [3094] DEBUG - Completed: [127.0.0.1:55370] 206 PUT /video/:/transcode/session/8f64587ec8a41fd3-com-plexapp-android/747a2993-d78f-4901-b937-2b42a46db8ab/progress?progress=78.6&size=-22&remaining=2567&speed=0.5 (10 live) 2ms 326 bytes
Aug 17, 2017 14:50:52.734 [3094] DEBUG - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Aug 17, 2017 14:50:52.734 [3094] DEBUG - Auth: authenticated user 1 as abarbaccia
Aug 17, 2017 14:50:52.734 [3094] DEBUG - Auth: Came in with a super-token, authorization succeeded.
Aug 17, 2017 14:50:52.735 [5282] DEBUG - Request: [192.168.1.130:42443 (Subnet)] GET /:/timeline?bandwidth=5687&bufferedTime=21&containerKey=%2FplayQueues%2F77&duration=6032000&guid=com.gracenote.tms%3A%2F%2Fmovie%2FMV000420020000&key=%2Flibrary%2Fmetadata%2F2040&machineIdentifier=d8793166988cd8f6a74e18b775f871de3ebd28c5&playQueueItemID=389&ratingKey=2040&state=playing&time=4658954&token=xxxxxxxxxxxxxxxxxxxx (10 live) TLS GZIP Signed-in Token (abarbaccia)
Aug 17, 2017 14:50:52.736 [5282] DEBUG - Client [8f64587ec8a41fd3-com-plexapp-android] reporting timeline state playing, progress of 4658954/6032000ms for guid=com.gracenote.tms://movie/MV000420020000, ratingKey=2040 url=, key=/library/metadata/2040, containerKey=/playQueues/77, metadataId=2040
Aug 17, 2017 14:50:52.741 [5282] DEBUG - Play progress on 2040 'Bad Boys' - got played 4658954 ms by account 1!
Aug 17, 2017 14:50:52.741 [5282] DEBUG - [Now] User is abarbaccia (ID: 1)
Aug 17, 2017 14:50:52.742 [5282] DEBUG - [Now] Device is Android (SHIELD Android TV).
Aug 17, 2017 14:50:52.742 [5282] DEBUG - [Now] Profile is Android
Aug 17, 2017 14:50:52.742 [5282] DEBUG - [Now] Updated play state for /library/metadata/2040.
Aug 17, 2017 14:50:52.742 [5282] DEBUG - Statistics: (8f64587ec8a41fd3-com-plexapp-android) Reporting active playback in state 0 of type 1 (scrobble: 0) for account 1
Aug 17, 2017 14:50:52.746 [3094] DEBUG - Completed: [192.168.1.130:42443] 200 GET /:/timeline?bandwidth=5687&bufferedTime=21&containerKey=%2FplayQueues%2F77&duration=6032000&guid=com.gracenote.tms%3A%2F%2Fmovie%2FMV000420020000&key=%2Flibrary%2Fmetadata%2F2040&machineIdentifier=d8793166988cd8f6a74e18b775f871de3ebd28c5&playQueueItemID=389&ratingKey=2040&state=playing&time=4658954&token=xxxxxxxxxxxxxxxxxxxx (10 live) TLS GZIP 11ms 749 bytes (pipelined: 1)
Aug 17, 2017 14:50:55.631 [3094] DEBUG - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Aug 17, 2017 14:50:55.631 [3094] DEBUG - Auth: Came in with the master token, authorization succeeded.
Aug 17, 2017 14:50:55.631 [5266] DEBUG - Request: [127.0.0.1:55372 (Loopback)] PUT /video/:/transcode/session/8f64587ec8a41fd3-com-plexapp-android/747a2993-d78f-4901-b937-2b42a46db8ab/progress?progress=78.6&size=-22&remaining=22445&speed=0.0 (11 live) Signed-in Token (abarbaccia)
Aug 17, 2017 14:50:55.633 [3094] DEBUG - Completed: [127.0.0.1:55372] 206 PUT /video/:/transcode/session/8f64587ec8a41fd3-com-plexapp-android/747a2993-d78f-4901-b937-2b42a46db8ab/progress?progress=78.6&size=-22&remaining=22445&speed=0.0 (11 live) 1ms 326 bytes
Aug 17, 2017 14:50:56.522 [3094] DEBUG - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Aug 17, 2017 14:50:56.523 [3094] DEBUG - Auth: Came in with the master token, authorization succeeded.
Aug 17, 2017 14:50:56.523 [5126] DEBUG - Request: [127.0.0.1:55373 (Loopback)] PUT /video/:/transcode/session/8f64587ec8a41fd3-com-plexapp-android/747a2993-d78f-4901-b937-2b42a46db8ab/progress?progress=78.6&size=-22&remaining=21601&speed=1.7 (10 live) Signed-in Token (abarbaccia)
Aug 17, 2017 14:50:56.524 [3094] DEBUG - Completed: [127.0.0.1:55373] 206 PUT /video/:/transcode/session/8f64587ec8a41fd3-com-plexapp-android/747a2993-d78f-4901-b937-2b42a46db8ab/progress?progress=78.6&size=-22&remaining=21601&speed=1.7 (10 live) 1ms 326 bytes
Aug 17, 2017 14:50:58.626 [3094] DEBUG - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Aug 17, 2017 14:50:58.626 [3094] DEBUG - Auth: Came in with the master token, authorization succeeded.
Aug 17, 2017 14:50:58.627 [5281] DEBUG - Request: [127.0.0.1:55374 (Loopback)] PUT /video/:/transcode/session/8f64587ec8a41fd3-com-plexapp-android/747a2993-d78f-4901-b937-2b42a46db8ab/progress?progress=78.6&size=-22&remaining=5086&speed=0.1 (11 live) Signed-in Token (abarbaccia)
Aug 17, 2017 14:50:58.628 [3093] DEBUG - Completed: [127.0.0.1:55374] 206 PUT /video/:/transcode/session/8f64587ec8a41fd3-com-plexapp-android/747a2993-d78f-4901-b937-2b42a46db8ab/progress?progress=78.6&size=-22&remaining=5086&speed=0.1 (11 live) 1ms 326 bytes
Aug 17, 2017 14:50:59.885 [3093] DEBUG - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Aug 17, 2017 14:50:59.886 [3093] DEBUG - Auth: Came in with the master token, authorization succeeded.
Aug 17, 2017 14:50:59.886 [5282] DEBUG - Request: [127.0.0.1:55375 (Loopback)] PUT /video/:/transcode/session/8f64587ec8a41fd3-com-plexapp-android/747a2993-d78f-4901-b937-2b42a46db8ab/progress?progress=78.6&size=-22&remaining=13151&speed=0.1 (12 live) Signed-in Token (abarbaccia)
Aug 17, 2017 14:50:59.887 [3093] DEBUG - Completed: [127.0.0.1:55375] 206 PUT /video/:/transcode/session/8f64587ec8a41fd3-com-plexapp-android/747a2993-d78f-4901-b937-2b42a46db8ab/progress?progress=78.6&size=-22&remaining=13151&speed=0.1 (11 live) 1ms 326 bytes
Aug 17, 2017 14:50:59.976 [3094] DEBUG - Completed: [192.168.1.130:42389] 200 GET /video/:/transcode/universal/session/8f64587ec8a41fd3-com-plexapp-android/base/01560.ts (11 live) TLS 12255ms 5590180 bytes (pipelined: 12)
Aug 17, 2017 14:50:59.984 [5266] DEBUG - Request: [127.0.0.1:55376 (Loopback)] POST /video/:/transcode/session/8f64587ec8a41fd3-com-plexapp-android/747a2993-d78f-4901-b937-2b42a46db8ab/seglist (12 live) Signed-in
Aug 17, 2017 14:50:59.988 [5126] DEBUG - Request: [192.168.1.130:42389 (Subnet)] GET /video/:/transcode/universal/session/8f64587ec8a41fd3-com-plexapp-android/base/01561.ts (10 live) TLS Signed-in
Aug 17, 2017 14:50:59.988 [5126] DEBUG - Asked for segment 1561 from session.
Aug 17, 2017 14:51:00.002 [5126] DEBUG - Returning segment 1561 from session: /storage/ORION/media/temp/Transcode/Sessions/plex-transcode-8f64587ec8a41fd3-com-plexapp-android-747a2993-d78f-4901-b937-2b42a46db8ab/media-01561.ts
Aug 17, 2017 14:51:00.010 [5126] DEBUG - Content-Length of /storage/ORION/media/temp/Transcode/Sessions/plex-transcode-8f64587ec8a41fd3-com-plexapp-android-747a2993-d78f-4901-b937-2b42a46db8ab/media-01561.ts is 5209104.
Aug 17, 2017 14:51:00.011 [3094] DEBUG - Completed after connection close: [127.0.0.1:55376] 200 POST /video/:/transcode/session/8f64587ec8a41fd3-com-plexapp-android/747a2993-d78f-4901-b937-2b42a46db8ab/seglist (10 live) 27ms 100 bytes
Aug 17, 2017 14:51:00.174 [5282] DEBUG - Request: [127.0.0.1:55378 (Loopback)] POST /video/:/transcode/session/8f64587ec8a41fd3-com-plexapp-android/747a2993-d78f-4901-b937-2b42a46db8ab/seglist (10 live) Signed-in
Aug 17, 2017 14:51:00.183 [3093] DEBUG - Completed after connection close: [127.0.0.1:55378] 200 POST /video/:/transcode/session/8f64587ec8a41fd3-com-plexapp-android/747a2993-d78f-4901-b937-2b42a46db8ab/seglist (10 live) 9ms 100 bytes
Aug 17, 2017 14:51:00.416 [3093] DEBUG - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Aug 17, 2017 14:51:00.416 [3093] DEBUG - Auth: Came in with the master token, authorization succeeded.
Aug 17, 2017 14:51:00.416 [5281] DEBUG - Request: [127.0.0.1:55379 (Loopback)] PUT /video/:/transcode/session/8f64587ec8a41fd3-com-plexapp-android/747a2993-d78f-4901-b937-2b42a46db8ab/progress?progress=78.7&size=-22&remaining=8564&speed=5.4 (10 live) Signed-in Token (abarbaccia)
Aug 17, 2017 14:51:00.417 [5281] DEBUG - Session 8f64587ec8a41fd3-com-plexapp-android (3) is throttling
Aug 17, 2017 14:51:00.417 [3093] DEBUG - Completed: [127.0.0.1:55379] 206 PUT /video/:/transcode/session/8f64587ec8a41fd3-com-plexapp-android/747a2993-d78f-4901-b937-2b42a46db8ab/progress?progress=78.7&size=-22&remaining=8564&speed=5.4 (10 live) 1ms 342 bytes
Aug 17, 2017 14:51:00.421 [5266] DEBUG - [Transcoder] Throttle - Going into sloth mode.
Aug 17, 2017 14:51:00.496 [3094] DEBUG - Completed: [192.168.1.130:42389] 200 GET /video/:/transcode/universal/session/8f64587ec8a41fd3-com-plexapp-android/base/01561.ts (11 live) TLS 509ms 5209104 bytes (pipelined: 13)
Aug 17, 2017 14:51:00.506 [5282] DEBUG - Request: [192.168.1.130:42389 (Subnet)] GET /video/:/transcode/universal/session/8f64587ec8a41fd3-com-plexapp-android/base/01562.ts (10 live) TLS Signed-in
Aug 17, 2017 14:51:00.507 [5282] DEBUG - Asked for segment 1562 from session.
Aug 17, 2017 14:51:00.507 [5282] DEBUG - Returning segment 1562 from session: /storage/ORION/media/temp/Transcode/Sessions/plex-transcode-8f64587ec8a41fd3-com-plexapp-android-747a2993-d78f-4901-b937-2b42a46db8ab/media-01562.ts
Aug 17, 2017 14:51:00.510 [5282] DEBUG - Content-Length of /storage/ORION/media/temp/Transcode/Sessions/plex-transcode-8f64587ec8a41fd3-com-plexapp-android-747a2993-d78f-4901-b937-2b42a46db8ab/media-01562.ts is 8563212.
Aug 17, 2017 14:51:00.755 [5126] DEBUG - Request: [192.168.1.130:42455 (Subnet)] GET /video/:/transcode/universal/session/8f64587ec8a41fd3-com-plexapp-android/base/01565.ts (10 live) TLS Signed-in
Aug 17, 2017 14:51:00.755 [5126] DEBUG - Asked for segment 1565 from session.
Aug 17, 2017 14:51:00.755 [5126] DEBUG - Returning segment 1565 from session: /storage/ORION/media/temp/Transcode/Sessions/plex-transcode-8f64587ec8a41fd3-com-plexapp-android-747a2993-d78f-4901-b937-2b42a46db8ab/media-01565.ts
Aug 17, 2017 14:51:00.757 [5126] DEBUG - Content-Length of /storage/ORION/media/temp/Transcode/Sessions/plex-transcode-8f64587ec8a41fd3-com-plexapp-android-747a2993-d78f-4901-b937-2b42a46db8ab/media-01565.ts is 5312880.
Aug 17, 2017 14:51:01.029 [3093] DEBUG - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Aug 17, 2017 14:51:01.029 [3093] DEBUG - Auth: Came in with the master token, authorization succeeded.
Aug 17, 2017 14:51:01.029 [5281] DEBUG - Request: [127.0.0.1:55384 (Loopback)] PUT /video/:/transcode/session/8f64587ec8a41fd3-com-plexapp-android/747a2993-d78f-4901-b937-2b42a46db8ab/progress?progress=78.7&size=-22&remaining=3552 (10 live) Signed-in Token (abarbaccia)
Aug 17, 2017 14:51:01.030 [5281] DEBUG - Session 8f64587ec8a41fd3-com-plexapp-android (3) is unthrottling
Aug 17, 2017 14:51:01.030 [3093] DEBUG - Completed: [127.0.0.1:55384] 206 PUT /video/:/transcode/session/8f64587ec8a41fd3-com-plexapp-android/747a2993-d78f-4901-b937-2b42a46db8ab/progress?progress=78.7&size=-22&remaining=3552 (10 live) 1ms 326 bytes
Aug 17, 2017 14:51:01.032 [5266] DEBUG - [Transcoder] Throttle - Getting back to work.
Aug 17, 2017 14:51:02.734 [3093] DEBUG - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Aug 17, 2017 14:51:02.734 [3093] DEBUG - Auth: authenticated user 1 as abarbaccia
Aug 17, 2017 14:51:02.734 [3093] DEBUG - Auth: Came in with a super-token, authorization succeeded.
Aug 17, 2017 14:51:02.735 [5282] DEBUG - Request: [192.168.1.130:42458 (Subnet)] GET /:/timeline?bandwidth=99120&bufferedTime=0&containerKey=%2FplayQueues%2F77&duration=6032000&guid=com.gracenote.tms%3A%2F%2Fmovie%2FMV000420020000&key=%2Flibrary%2Fmetadata%2F2040&machineIdentifier=d8793166988cd8f6a74e18b775f871de3ebd28c5&playQueueItemID=389&ratingKey=2040&state=playing&time=4726872&token=xxxxxxxxxxxxxxxxxxxx (12 live) TLS GZIP Signed-in Token (abarbaccia)
Aug 17, 2017 14:51:02.736 [5282] DEBUG - Client [8f64587ec8a41fd3-com-plexapp-android] reporting timeline state playing, progress of 4726872/6032000ms for guid=com.gracenote.tms://movie/MV000420020000, ratingKey=2040 url=, key=/library/metadata/2040, containerKey=/playQueues/77, metadataId=2040
Aug 17, 2017 14:51:02.738 [3093] DEBUG - handleStreamRead code 335544539: short read
Aug 17, 2017 14:51:02.739 [5282] DEBUG - Play progress on 2040 'Bad Boys' - got played 4726872 ms by account 1!
Aug 17, 2017 14:51:02.739 [5282] DEBUG - [Now] User is abarbaccia (ID: 1)
Aug 17, 2017 14:51:02.739 [5282] DEBUG - [Now] Device is Android (SHIELD Android TV).
Aug 17, 2017 14:51:02.739 [5282] DEBUG - [Now] Profile is Android
Aug 17, 2017 14:51:02.739 [5282] DEBUG - [Now] Updated play state for /library/metadata/2040.
Aug 17, 2017 14:51:02.740 [5282] DEBUG - Statistics: (8f64587ec8a41fd3-com-plexapp-android) Reporting active playback in state 0 of type 1 (scrobble: 0) for account 1
One more log which may provide more details. Seems like it can’t find the hardware decoder on the nVidia shield.
.Aug 17, 2017 20:30:04.288 [19825] DEBUG - Cleaning directory for session bcabfd5b-7d28-4d02-8ec9-2dd7b982493b ()
Aug 17, 2017 20:30:04.290 [19825] DEBUG - Starting a transcode session bcabfd5b-7d28-4d02-8ec9-2dd7b982493b at offset -1.0 (state=3)
Aug 17, 2017 20:30:04.290 [19825] DEBUG - Streaming Resource: Added session 0x203a3150a0:bcabfd5b-7d28-4d02-8ec9-2dd7b982493b
Aug 17, 2017 20:30:04.297 [19825] DEBUG - TPU: hardware transcoding: enabled, but no hardware decode accelerator found
Aug 17, 2017 20:30:04.297 [19825] DEBUG - TPU: hardware transcoding: final decoder: , final encoder:
Aug 17, 2017 20:30:04.311 [19825] DEBUG - Job running: EAE_ROOT='/data/user/0/com.plexapp.mediaserver.smb/tmp/pms-edd0ed22-cbad-4cdf-925a-34bdbab70830/EasyAudioEncoder' FFMPEG_EXTERNAL_LIBS='/data/user/0/com.plexapp.mediaserver.smb/Plex\ Media\ Server/Codecs/798f007-1247-android-aarch64/' XDG_CACHE_HOME='/storage/emulated/0/Android/data/com.plexapp.mediaserver.smb/cache/' XDG_DATA_HOME='/data/user/0/com.plexapp.mediaserver.smb/Resources/' X_PLEX_TOKEN='xxxxxxxxxxxxxxxxxxxx' '/data/user/0/com.plexapp.mediaserver.smb/Resources/Plex Transcoder' '-noaccurate_seek' '-ignore_unknown' '-scan_all_pmts' '-1' '-i' 'http://192.168.1.156:5004/auto/v699' '-map' '0:V?' '-codec:V' 'copy' '-map' '0:a?' '-codec:a' 'copy' '-copypriorss:a' '0' '-map' '0:s?' '-codec:s' 'copy' '-segment_format' 'mpegts' '-f' 'ssegment' '-individual_header_trailer' '0' '-segment_time' '1' '-segment_start_number' '0' '-segment_copyts' '1' '-segment_time_delta' '0.0625' '-segment_list' 'http://127.0.0.1:32400/video/:/transcode/session/bcabfd5b-7d28-4d02-8ec9-2dd7b982493b/63b36946-b165-45c5-8c65-65bac4ee6dc3/seglist' '-segment_list_type' 'csv' '-segment_list_size' '2147483647' '-max_delay' '5000000' '-avoid_negative_ts' 'disabled' '-map_metadata' '-1' '-map_chapters' '-1' 'media-%05d.ts' '-start_at_zero' '-copyts' '-vsync' 'cfr' '-y' '-nostats' '-loglevel' 'quiet' '-loglevel_plex' 'error' '-progressurl' 'http://127.0.0.1:32400/video/:/transcode/session/bcabfd5b-7d28-4d02-8ec9-2dd7b982493b/63b36946-b165-45c5-8c65-65bac4ee6dc3/progress'
I remuxed the mpeg2tx file into an MKV container and tested it on the same box. The playback is now hardware accelerated and no studdering when seeking. Also, the audio sync remained in tack.
Plex devs, hopefully this is helpful in making the nvidia sheild more usable. Either enable hardware acceleration of the mpeg2ts container or option to remux recordings to mkv…
If you Remux you loose subtitles. The plex app on shield uses exoplayer and it doesn’t like the .ts format; for reliable playback I have to use the plex for kodi addon and play via kodi.
