After recently upgrading to 0.7.1 I’m having issues with stuttering while playing m4v and mp4 movies. MKV movies seem fine however. .7.0 didn’t display this issue.
RPi-2 on wifi, plays most things fine but is choking on m4v and mp4 movies, plays really fast for a few seconds and then starts skipping.
RPi-B on LAN, same but also is skipping when playing certain mp3 files. Issue reported in a different thread.
PMS: .9.12.11 on Synology NAS DS415+. I tried .9.12.12 but it stuttered even more actually. Nearly no CPU use while the movie is stuttering so I don’t think it’s transcoding.
Please enable debug logging in Preferences and attach both RasPlex and PMS log to this forum topic.
If possible also a link to a sample file you are having problems with.
@NedtheNerd said:
Try changing the sync to audio or sync to video settings from default or turning on adjust display refresh rate to match video.
Regards
Thanks, I tried your suggestions, but it didn’t have any effect. Just to clarify - I’m not experiencing audio/video sync issues, just a jerky video. Simple remux to mkv or force transcode and the the jerkiness is gone.
I am also having this problem. I did notice that the stuttering seemed to reduce considerably if I disabled FFMPEG AVIO. I still get the occasional stutter but before disabling this feature it was every 20 seconds.
I have not tried anything else. I am hesitant to go back to 0.7.0 because that release is listed as retired and not as stable or even pre-release. Is 0.7.0 stable enough I should give it a try? I’ve never tried it. I upgraded from 0.6.0.
Also, I notice it doesn’t appear in the rasplex installer’s download list. I guess I would need to go to Github and download it manually? I would have gone back to 0.6.0 but the menu’s appear to be considerably more snappy after this upgrade and I really hate to give that up
I am configured for Direct Play whenever possible and there was no trans-coding while playing my sample movie.
My setup:
Raspberry Pi 2 Model B running Rasplex 0.7.1
Wired 1Gig network connection to 1Gig Uplink
PMS on Windows 8 PC with 12GB RAM on i7 quad core.
PMS 0.9.12.11
@NedtheNerd said:
Can someone mark this as answered please.
Regards.
Isn’t the originator of this thread the only one that can do that? Otherwise I would agree, this should be marked as answered as well. Release 1.0.0 has solved this issue.
