Some files won't run smoothly. Framerate?
Hello Guys,
I did a quick test in my environment. Two critical 1080p's are working fine. But some of my 720p series are having trouble. Sound is really smoothly, but video isn't good. I wouldn't say that is stuttering, it's more not running smoothly.
Server running on Synology DS412+ 0.9.7.28, RasPlex version 0.2.2
Here are some infos about the used files:
This one is bad:
General
Unique ID                                : xxxxxxxxxxx
Complete name                            : \\DISKSTATION\video est.mkv
Format                                   : Matroska
Format version                           : Version 2
File size                                : 1.47 GiB
Duration                                 : 41mn 19s
Overall bit rate                         : 5 102 Kbps
Movie name                               : Test
Encoded date                             : UTC 2012-11-25 16:10:07
Writing application                      : mkvmerge v5.8.0 ('No Sleep / Pillow') built on Sep  2 2012 15:37:04
Writing library                          : libebml v1.2.3 + libmatroska v1.3.0
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : High@L3.1
Format settings, CABAC                   : No
Format settings, ReFrames                : 2 frames
Codec ID                                 : V_MPEG4/ISO/AVC
Duration                                 : 41mn 19s
Bit rate                                 : 4 104 Kbps
Width                                    : 1 280 pixels
Height                                   : 720 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 25.000 fps
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.178
Stream size                              : 1.18 GiB (80%)
Default                                  : Yes
Forced                                   : No
Color primaries                          : BT.709
Transfer characteristics                 : BT.709
Matrix coefficients                      : BT.709
Audio #1
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Mode extension                           : CM (complete main)
Format settings, Endianness              : Big
Codec ID                                 : A_AC3
Duration                                 : 41mn 19s
Bit rate mode                            : Constant
Bit rate                                 : 448 Kbps
Channel(s)                               : 6 channels
Channel positions                        : Front: L C R, Side: L R, LFE
Sampling rate                            : 48.0 KHz
Bit depth                                : 16 bits
Compression mode                         : Lossy
Stream size                              : 132 MiB (9%)
Language                                 : German
Default                                  : Yes
Forced                                   : No
Audio #2
Format                                   : AC-3
Codec ID                                 : A_AC3
Duration                                 : 41mn 19s
Bit rate                                 : 448 Kbps
Bit depth                                : 16 bits
Language                                 : English
Default                                  : No
Forced                                   : No
This one is good:
General
Complete name                            : \\DISKSTATION\video\Test2.mkv
Format                                   : Matroska
File size                                : 888 MiB
Duration                                 : 25mn 35s
Overall bit rate                         : 4 854 Kbps
Encoded date                             : UTC 2012-01-25 13:10:20
Writing application                      : mkvmerge v4.0.0 ('The Stars were mine') built on Jun  6 2010 16:18:42
Writing library                          : libebml v1.0.0 + libmatroska v1.0.0
Video
Format                                   : AVC
Format settings, GOP                     : N=1
Duration                                 : 25mn 35s
Bit rate                                 : 4 182 Kbps
Height                                   : 720 pixels
Frame rate                               : 23.976 fps
Color space                              : YUV
Bit depth                                : 8 bits
Bits/(Pixel*Frame)                       : 0.189
Stream size                              : 765 MiB (86%)
Language                                 : English
Default                                  : No
Forced                                   : No
Audio #1
Format                                   : AC-3
Format profile                           : Dolby Digital
Codec ID                                 : A_AC3
Duration                                 : 25mn 35s
Bit rate                                 : 192 Kbps
Channel(s)                               : 2 channels
Channel positions                        : Front: L R
Bit depth                                : 16 bits
Stream size                              : 35.1 MiB (4%)
Language                                 : German
Default                                  : Yes
Forced                                   : No
Audio #2
Format                                   : AC-3
Codec ID                                 : A_AC3
Duration                                 : 25mn 35s
Bit rate                                 : 384 Kbps
Bit depth                                : 16 bits
Stream size                              : 70.3 MiB (8%)
Language                                 : English
Default                                  : No
Forced                                   : No
Guys do you have any idea about this?
Is there an issue regarding video framerate 25fps and 23,976fps?
Just PLEX for Samsung is working fine with the files.
BTW: Same issue with plexconnect and ATV3. Already posted there. I thought running RasPlex would be better. FAIL ;-)
FYI - problem solved with 0.3.1
____________
THX to the devs
