SubFolders / SubSections
Hello,
It would be a good option to make subsections or subfolders in the PMS, like follow.
Is it possible to make subsections like, FILMS--->AUGUST--->for KIDS
        ---->for ADULTS ...etc.
If it's able, it will be good to chooose for the sub sections different scanners, like tvshows, for kids, and film scanner for adults, etc.
I would like to ask min. two level deep subsystem, but it's perfect if its multiple level.
YS: Probadroid
You can create multiple movies sections, this will allow using different scanner etc.
You cannot create one movie section and sub divide it.
Don't know if thats what you're after?
I know what I can and what I cannot do.
That's why I made a decision to write here, in the dev. forum, to make an advise what I looking for in the next version.
this should not go into the dev forum, but into the Feature & Bug Voting forum.
Thank you very much!
Could someone put this topic over there, or I  must open this topic in that forum too?
Little harsh my friend, i was only making sure you knew the current implementation incase it suited your requirements or you didn't understand it.
