Subtitle offset not reset between files
Server Version#: Version 1.25.5.5492 (Running on Ubuntu 20.04)
Player Version#: 1.40.1.2823 (Win 10)
Steps to reproduce
  1. Play any video file with subtitles
  2. Download external subtitles from OpenSubtitles
  3. Adjust the subtitle offset
  4. Start playing another video file with built-in subtitles or with subtitles downloaded from OpenSubtitles
  5. See the subtitle offset carried over to the next file (UI shows 0ms as the offset, but the subtitle offset is wrong)
  6. Resetting the subtitle offset (if possible) or restarting the PMP fixes the problem
Current behavior
  1. Subtitle offset is carried over to next file
Expected behavior
  1. Set subtitle offset is not applied to other media files
I’ve recently noticed this also, however in my case it seems to also be effecting files with built in subtitles where the subtitle offset option is grayed out, forcing me back to the previous episode to reset the offset and then back to whatever I actually wanted to watch.
Kind of a pain.
