Server Version#: 1.40.0.7998
Player Version#: latest
The subtitles on some shows are on the left side of the screen when using a Playstation 5:
On every other Device (Windows+Chrome, Mobile App) the subtitles are centered:
Is this a bug or a feature?
What type of subtitles are they? I cannot reproduce. Can you share the subtitle file?
out.srt (52.1 KB)
yeah, i used ffmpeg to export the subtitles, hope that’s okay.
1
00:00:00,967 --> 00:00:02,167
<font size="41">{\an1}[intriguing celeste music]</font>
2
00:00:02,300 --> 00:00:03,800
<font size="41">{\an1}Okay, Steven. Ready to go?</font>
Your subtitle file has positioning info that the app is respecting. The {\an1} means to put the subtitles on the bottom left.
Okay, I cleaned my subtitle Files. Thanks for the help.
Follow up question: In the Plex Player there is a setting for subtitle Position, but it only has the options for bottom, middle and top. Would it be possible for you to add the options left and right?
