Subtitle out of sync.
I’m guessing this problem concerns all platforms.
IN some shows the subtitles will graduly get out of sync. Is there a way to delay or speed up the subtitles. Up to 10 seconds in 100ms steps would be great.
Can you confirm that this is 100% a Plex issue first? I’d narrow that down initially by using a player like VLC to play the show and load the subtitle file and watch it that way. Then you can confirm that Plex is causing the issue and it’s not a problem with the .srt file
To directly address what you asked though - I don’t know the answer, but you might get a bit more traction in the forums if you provide the above background first.
Of course not. This is not something that Plex is responsible for. I’m looking for a way to delay the subtitles so they can be in sync with the video/audio. If it isn’t available I would suggest it should be implemented. Every good video player has it, so why not Plex?
