Subtitle selection bugs - Portuguese subtitles
BUG 1:
Current behaviour:
Plex Server has three portuguese entries on the prefer subtitles dropdown menu: Português, Português (Brasil) and Português Brasileiro.
If you select Português Brasileiro and apply. Plex Server bugs and actually selects “Abkhazian”.
Expected behaviour:
After selecting “Português Brasileiro” from the dropdown menu. The server refreshes the media and auto selects Brazilian Portuguese subtitles.
BUG 2:
Current behaviour:
If you select Português (Brasil), Plex seems to ignore this setting and picks the first available subtitle for a show (usually English).
Expected behaviour:
After selecting “Português (Brasil)” from the dropdown menu. The server refreshes the media and auto selects Brazilian Portuguese subtitles.
BUG 3:
Current behaviour:
If you select Português, Plex seems indeed picks a portuguese subtitles from the available subtitles list, however, if there are two portuguese subtitles, it will always pick the first one, without checking if it’s meant for Portugal or Brazil.
Expected behaviour:
After selecting “Português” from the dropdown menu. The server refreshes the media and auto selects Portuguese, and not Brazilian Portuguese subtitles.
Same… no idea how to fix this… it’s my biggest complain with Plex… always a few minutes in when I get that the wrong Portuguese is selected and I need to manually change it… frustrating! Hopefully this is fixed or a workaround is found!
