Server Version#: 1.14.1.5488
Player Version#: 3.77.4
I would like to have the subtitles displayed in yellow.
I changed the plexmediaplayer.conf file accordingly (“color”: “#FFFF00,#000000”).
I restarted PMP but it doesn’t work.
Thanks for any help.
You must use the settings section of PMP to select a subtitle color.
Put PMP into the TV mode:
Then select+Enter your user avatar
Settings - Subtitles - Color
You can switch back to the desktop layout afterwards, if you want.
Thanks a lot !
