Subtitles mkv movie
I can't see the subtitles of a mkv movie in the apple tv. The subtitles are ok if I play the movie in my MAC (VLC). Any help?
Are you selecting the subs on the pre-play screen?
Yes!, there I can see all the languages I can select, but they don't appear when I'm watching the movie.
Do they appear if you use the iOS/desktop/android client and if so which ones?
OS X 10.8.4
Plex Media Server: 0.9.7.28
APTV3 5.2.1
I've got the same problem with subtitles and movies. TVShows (mkv) with external subs (srt) works. I can select on preplay screen and PMS subtitle "unknown (srt)". For movies (mkv) and external subs (srt) i can't select the external subs. It only shows internal subs from mkv file. "unknown (srt)" is not available and selectable. The names of the mkv and srt files are the same.
yes i have too this problem, the subtitles work only from internal and not from external HDD
Hi Rocky star, thank you for your help!. I'm not sure I understand your question. They appear in my desktop using VLC. I can choose English, Spanish, Chinese, Japanese....Using Plex Media Server and APTV, I can select them in the pre-play screen but doesn't work. The subtitles are internal, not (srt) external.
The question is...
Do those subtitles work in any other Plex based client - preferably iOS?
VLC is a completely different story, there is no PMS involved!
Here the Media Info:
MEDIA
•       Duration 1:50:43
•       Bitrate 10279 kbps
•       Width 1920
•       Height 800
•       Aspect Ratio 2.35
•       Video Resolution 1080p
•       Container MKV
•       Video Frame Rate 24p
FILE
•       Accessible Yes
•       Exists Yes
•       Duration 1:50:43
•       File /Users/Sergio/Movies/Kill Bill Vol. 1 2003 BluRay 1080p ac3 x264-LoNeWoLf.mkv
•       Size 7.95 GB
•       Container MKV
VIDEO
•       Codec H264
•       Bitrate 9640 kbps
•       Language English
•       Bit Depth 8
•       CABAC 1
•       Chroma Subsampling 4:2:0
•       Color Space yuv
•       Duration 1:50:43
•       Frame Rate 23.976 fps
•       Frame Rate Mode cfr
•       Has Scaling Matrix 0
•       Height 800
•       Level 4.1
•       Profile high
•       Ref Frames 4
•       Scan Type progressive
•       Width 1920
AUDIO
•       Codec AC3
•       Channels 5.1
•       Bitrate 640 kbps
•       Language English
•       Bit Depth 16
•       Bitrate Mode CBR
•       Dialog Norm -31 dB
•       Duration 1:50:43
•       Sampling Rate 48000 Hz
SUBTITLES
•       Language English
•       Format PGS
SUBTITLES
•       Language Español
•       Format PGS
SUBTITLES
•       Language 日本語
•       Format PGS
SUBTITLES
•       Language 한국어
•       Format PGS
SUBTITLES
•       Language 中文
•       Format PGS
SUBTITLES
•       Language English
•       Format PGS
SUBTITLES
•       Language Français
Format PGS
No subtitles If I play the movie in my desktop with Plex Media Server. Do you need any other information?
im having the same issue, subtitle works on ipad but not with plexconnect even though i can choose the subtitle on the pre play screen :-/
I have solved the problem including external srt subtitles
The question is.... How?
Following this guide:
http://wiki.plexapp.com/index.php/PlexNine_PMS_Subtitles
Thanks!
What specifically did you do?
Rename them, convert them or something else?
Subtitle and movie files with exactly the same name and in Plex Media Server Settings, Agents, Freebase: mark all the options. In opensubtitles.org, select Language 1 and Language 2. English and Spanish in my case. Finally choose your preferences in Languages.
how do i get the subtitles in the mkv file to work then ?
here you have an example:
http://subscene.com/subtitles/the-master
