Subtitles Scanner?
Is it possible?
I've seen a lot of discussion on the boards, of different ways to deal with subtitles and where/how to get subtitles. Recently I've been reading about a python package called Periscope which provides functionality to find/download subtitles from several different open sources, based on several options (filename, scene release, video hash, etc.).
It got me thinking, since PMM (or the scanners) are scanning every file as they are added to the library and downloading appropriate metadata, it makes sense to add the subtitle-sourcing step to this workflow. I have no idea if it's possible but, what I envision is a scanner (I think is the right term) which checks if a video file has an associated subtitle file or subtitles embedded in the container and if not, passes the file to Periscope in order to retrieve the appropriate subtitles. Users would have to be able to set their preferred language(s).
As I mentioned already, I have no idea I this is possible but it seems like it should be. I don' have the faintest idea how/where to start. If someone is interested in trying to tackle this, I think it would be very well received.
This would be sooo sweet
There is an opensubtitles.org agent, but it does not seem to work, at least not for me ;).
it does work, it just doesnt do what you think it does.
right now the opensubtitles.org agent is only used to help with movie *matching* (by checking the file hash against their database of scene releases), it currently doesn't grab any subtitles for you, although this is something that is definitely planned/in the works. I could be mistaken, but i dont think you can write your own agent to download subtitles right now, it will need support in PMS and the plugin framework.
Aha, ok. But then I am sure that it will be extended to download subtitles when possible.
