I have built my own subtitle agent for Swedish subtitles but would like to have the matches from opensubtitles as well. How do I achieve that?
I assume you built it so it shows up in the metadata agent listing under the gear icon in PMM right? What happens if you have both active?
Yes, it shows up under the gear icon. It seems that if I have both active and I find a match on the top most the lower one will not download any subs, but I've to do some more testing to really figure out what's happening. The lack of subtitle indicators don't mate it easier to debug :/
Ok, after some more testing and reading the logfiles from the opensubtitles.org agent it appeared that my opensubtitles.org plugin were broken some how. After a hard reset (Shutdown PMM, Remove Opensubtitles.bundle (so PMM can download the updated one) and started PMM again) everything seems to work now.
Hi, great with a Swedish sub agent.
Is it something you can release for the rest of us? Would love to use it.
Sure, the plugin thread is here http://forums.plexapp.com/index.php/topic/24360-undertexterse-lagom-till-nya-plex/ I'm using the latest checkin in github and it works ok both for tv-shows and movies.
