Howto enable automatic subtitle download
Hi, and sorry for that. I am not able to get the automatic subtitle download to work with the informations i found in the web. What i have done is:
Settings - Server - Language:
  • Subtitle always on
  • preferred language (English)
Settings - Server - agents - movies - freebase:
I created an account on opensubtitles and added the username and password in the settings window. I also added english to the first place to download.
Now i updated the media library but there is still no subtitle. Is there something i missed to get the automatic download running?
Thank you very much for your help.
plz help …
I followed the same steps (as listed in Plex Support) and still can’t get subs to work.
I got it working by downloading an external plug-in and installing it for subtitles. It’s called Subliminal. You can find it at: https://github.com/bramwalet/Subliminal.bundle
its not working for me either. worked before ike a sharm. after updating flex it stopped working.
therefore there has been some changes made by the developers.
please fix that, so we can fetch automatically subtitles with a proper open subtitles.org account
Is this thread dead? I am having the same issue. Please make subtitles work!
Same here. Furthermore: I cannot get local subtitle files (.srt) nor subtitles from OpenSubtitles to work. Hence, no subtitles what so ever.
i tried subzero and cannot get that to work in 1.4 either…
@samip537 said:
I got it working by downloading an external plug-in and installing it for subtitles. It’s called Subliminal. You can find it at: GitHub - bramwalet/Subliminal.bundle: Plex Metadata agent plugin based on Subliminal
Which steps you followed to make it work? I installed the plug-in but still nothing works
I followed everything here and MADE SURE TO UPDATE METADATA FOR THAT FOLDER and it worked, thanks for the input. Make sure to manually update your metadata.
