ok, so I have a movie that is in English, but has some sequences in another language.
I prefer to watch movies in English with the English subtitles turned on.
I have 2 options:
- English Forced (SRT): this will enable English subtitles for everything that is spoken in the other language, but won’t show subs for everything spoken in English
- English (SRT): this will enable English subtitles for everything that is spoken in English, but won’t show subs for everything spoken in the other language
What do I need to set to have English subs for everything that is spoken in English as well as the other language ?
Use Subtitle Edit to edit the .srt subtitles to what ever you want.
Then I’d say that the subtitles you have are wrong.
If you don’t have a source for proper English subtitles, you can try and merge the two subtitles, thus generating a complete version of the English subs.
I concur with the above recommendation of Subtitle Edit
Thank you for the reply.
Why are the subtitles wrong ?
The subtitles are complete and Plex will show either one or the other depending on the setting.
So if Plex would have a setting to enable both (English SRT and English Forced SRT) then it would work as expected.
Can you please explain how this is not Plex’ fault ?
No, they are not. For an English speaker, they are supposed to also contain the lines from the “forced” subs. If they don’t, they can only be considered “incomplete” or “wrong”.
I can only assume that they were ripped from a disc. Particularly with VOBSUB format, it is quite common to have all subtitles in a common container, with the “forced” lines only carrying an additional flag on them.
Someone made a mistake while ripping them. Instead of storing all subtitles, the “forced” ones were removed, thus creating an incomplete file.
Understood, thanks again for the clarification
