Hi
Here is a thought as to how the DVR Program guide is setup for scheduling recordings.
Currently, if you traverse the upcoming items and get beyond one screen full of programs, when you select an item to record then return, the slider of shows resets to the start, making it difficult setting up new recordings as you have to start from the beginning of the list every time.
It would be nice if when you clicked on the item, the info and setting screen would be a pop-up window.
This way when you are done with that item, the item scroll thing will be in the same place so you can continue to look for items without having to start from the beginning of the list.
With all that said, let’s see what Plex does…
