Suggestion: Player améliorations Audio Tracks
It would be necessary to add an option to change audio track directly in the player of Plex server and the Plex mobile version.
(il faudrait ajouter une option pour changer de piste audio directement dans le player de Plex server et du Plex version mobile.)
This is already possible.
thx, but sometimes i have an option to change audio and sub, and sometimes not, i dont understand why…
  1. The simplest reason would be that the source file simply has no other audio or subtitle tracks.
  2. If you ‘Sync’ videos, the currently selected audio and subtitle streams are used and all others get discarded from the copy of the file that gets synced onto your device.
