I followed the link and logged in as admin but still no new options. Not under Settings → Library or under my Music library advanced settings.
Is your server only running a 32bit OS?
Yeah, it is Ubuntu 16, 32 bit.
Per the support article, Super Sonic is only available on 64 bit OSes.
I’d recommend migrating to a newer 64 bit OS, if your hardware supports it. Ubuntu no longer provides 32 bit installation media, and IIRC has stopped providing 32 bit packages in the repos for newer OSes. In addition to that, Ubuntu 16.04 is no longer supported with security or bugfix updates.
Yeah, you are not wrong on any of your points. I am nervous to pull the trigger as everything has worked well for 5 or 6 years now. I will look into it. Are you saying that’s my problem? That I don’t have a 64bit OS? That’s not mentioned in any of the literature I read.
Jo
Yeah, you’re running an unsupported architecture unfortunately. The support article I linked above (emphasis mine) says:
- You must be running Plex Media Server v1.24.0 or newer
- Windows, macOS, and Linux (64-bit only) are supported (this includes most NAS devices)
Thanks for the time. Will look at updating to 64-bit version.
UPDATE: Well the scan finished this morning at 4:36 AM! - completed 100.0% - Sonic Analysis.
Now after the long wait, time to see how this works!
