Question about Super Sonic features in Windows Plexamp and How to Use
Server Version#: 4.59.2
Player Version#: 3.5.0
I turned on Sonic Analysis last night (following the Get Started part of the blog) and really haven’t noticed anything different on Plexamp. Should it look different? Is there something specific I need to do to access the features?
All help is appreciated!
You’ll only see those new features once the sonic analysis of your music library is done. The only exception should be the grouping of albums by release type (album, live album, compilation, single/ep…).
Have you enabled the sonic feature 2x?
  1. in Settings > [Server Name] > Library > Analyze audio tracks for sonic features
  2. per music library by checking > Manage Library > Edit...Advanced > Sonic Analysis
If you’re using the hosted version of Plex Web (https://app.plex.tv/desktop) you should see the scan progressing during the specified maintenance times (see Settings > [Server Name] > Scheduled Tasks > Start Time / End Time).
Bonus question: on what platform are you running your server?
Thanks for getting back to me!
I believe I have everything enabled and have gone through scheduled maintenance. It is scheduled between 2 and 5am.
1.
2.image
My server is running on Ubuntu. It is an older Intel model but runs ok.
A couple of new tabs did come up when I upgraded servers but nothing specific to Super Sonic.
Thanks again,
Based on your configuration (#1), the sonic analysis should run as a scheduled task during the maintenance time window specified for your server. You can expand that time – however keep in mind that the sonic analysis will use a lot of your server’s CPU (approx. 50% of the available cores at full load) – especially with an older CPU this can take quite some time.
Thanks for the info. I’ll expand the window and wait.
It looks like the radio stations are now populating. Thanks for the help!
