In my opinion the article about the using of filters is a bit outdated (last modified almost 6 years ago). ![]()
https://support.plex.tv/articles/200392126-using-the-library-view/
It only explains the normal filters and has It has no information about how to use advanced filters (I guess they didn’t exist back then :).
Some points I’m missing here are:
- What are Rule Groups and how do you use them?
- How do the rules behave if you select “One of the following” or “All of the following” on top?
- Maybe: how they behave if you use 2 or 3 levels with arguments? I think some examples could be helpful for people who struggle with the structure of these advanced filters.
Thank you!
