Switching libraries feels weird on desktop devices
When switching the library/server in plexamp you have to long press the currently selected library, this feels extremely weird on desktop and since their is no hover effect you are also never sure that you long press the right spot which makes you stop your press to early and try it again at a slightly different spot.
I think on desktop the menu to switch the library/server should open with a simple click, it would also be nice if there was a hover effect there so that you know where you can click. On mobile the long press is perfectly fine and also prevents accidentally opening the menu this is just about desktop.
Not disputing your point… you can also right-click the library from the home screen header to bring up the library selection immediately.
Couldn’t that been added as a keyboard shortcut when the PlexAmp window was active?
I was actually thinking it should be a single tap/click on all platforms.
Yes please :100:
Yes please ! :slight_smile:
A single click would be more natural
Maybe turning it into a button like the Homescreen description would make it also more visible ?
