Server Version#: 1.32.4.7195
I am getting the following message almost continously in the Plex Settings - Manage - Console
IsDirectory failed boost::filesystem::status: Symbolic link loop [system:40]: “/sys/fs/btrfs/dc801228-f353-4dd4-9824-be9b0e4f4fa3/bdi/subsystem/1:0/subsystem/1:0/subsystem/1:0/subsystem/1:0/subsystem/1:0/subsystem/1:0/subsystem/1:0/subsystem/1:0/subsystem/1:0/subsystem/1:0/subsystem/1:0/subsystem/1:0/subsystem/1:0/subsystem/1:0/subsystem/1:0/subsystem/1:2/subsystem/7:7/subsystem/1:11/subsystem/1:9/subsystem/1:0”
Is this a problem and how can I stop it?
Did you create a symlink somewhere ?
I need to see the DEBUG logs where this came from.
Diagnosing the alert in isolation isn’t possible.
/sys/fs/btrfs implies a filesystem failure/corruption of BTRFS.
The obvious question – When was the volume last scrubbed ?
I’m not sure what a symlink is. Is there a way to check if I inadvertentIy set on up?
I did a websearch on the error and found that it could have been caused by Docker and I did setup Docker to use with Photoprism a while ago but I just removed all that setup and uninstalled Docker and I still have the messages.
I have set the Plex Debug Level to Enabled. How do I download the logs?
“The obvious question – When was the volume last scrubbed ?” Never as I have no idea what scrubbing is!
BTW, I am scrubbing my data now
I need to see your server logs ZIP.
Settings → Server → Troubleshooting (left side) → Download Logs
It will give you a ZIP file.
Upload that ZIP file.
I think you have an error in where you have PMS looking for media files.
Specifically, instead of looking in /volume1, /volume2, etc…
I think you accidentally have one library section pointing at /
EDIT each library section’s Folder list and make certain there are no errors.
If everything is correct,
- Restart the Syno
- Restart the scrub
The error code “40” is “too many symbolic links” … It means there is an infinite loop.
That’s a sign of corruption or a badly behaving program.
That was the problem! I found 1 library with a / and after removing it, the error stopped.
I am now scrubbing the data
Thanks so much!
