Sync is Dead (almost). Long Live Downloads! (Part 2 - iOS)
Server
Plex Media Server Logs_2021-09-23_21-10-01.zip (5.0 MB)
From iPad with similar problem
PlexDebugInfo-pallamf@mac.com-7.23-1076 (2021-09-23 22.06.10 -0400).zip (609.7 KB)
From iPhone
PlexDebugInfo-pallamf@mac.com-7.23-1076 (2021-09-23 22.08.24 -0400).zip (842.4 KB)
Im having issues with download.
So far tried an 2021 ipad pro, a iphone pro max, all have the same issue. It appears to work, but every single video file tv or movie is incomplete. It plays but you only get some of it. not all of it.
I checked the server never crashed during.
MovieFan.Plex, any thoughts after reviewing my logs?
@phreaq Your logs showed an ā€œunknown errorā€ so it’s going to take a bit of work to figure out what’s going on. It looks like it finished the download. Can you check using the library view and see if the episode is there and playable? I’m wondering if it’s just the items page having an issue with the status notification.
@anon18523487, the shows aren’t downloading to the device. If I take it offline, it won’t play the episodes. Also, whenever I re-open Plex it tries to download the same show again and again.
Huh, the logs show it got to 100%.
@anon18523487 so what should I do next? I’m unable to download any content.
Well, I see this has been mentioned before (a lot), but I just switched to download from sync on an iPhone iOS15 and an iPad iPadOS15, and could not download on the iPhone. On the iPad, I was able to download one movie and 1 TV Season, but now nothing would download.
There is only on the overview a possibility to download. With no function (download doesnt start). If you are on the film overview, there is no button for download.
Sync doenst work since update, changed to download, no possibility to download.
Pls help
Server Version 1.24.3.5033
Android 8.23.1.28053
Just had a look on another mobile. There is a downloadbutton and it works. But on this Samsung Tablet it doesnt display a downloadbutton its a full white circle instead of a full withe circle with download-symbol. The download-symbol is missing as the function is missing.
Downloads are such a step back compared to Sync.
When I start watching a video that I have downloaded to my phone from the Home screen, Plex streams the video over the cellular network, even though the file is downloaded and I have selected Prefer downloaded content. How stupid is that???
I so regret to have moved away from Sync.
Just hang tight. We’re investigating.
We haven’t tested on 15 yet, since it just came out. Please provide logs after reproducing the problem so we can see if there is something we can identify quickly.
Do you have the option enabled to prefer Synced/Downloaded content? If not, it will try to stream from your server.
A post was merged into an existing topic: Sync is Dead (almost). Long Live Downloads!
Yes, as I wrote, that option is ticked.
Settings - Advanced - Player - Prefer downloaded content is ticked.
Or is there another setting?
Ok, can you playback that file again and get me the ios logs.
Here are the iOS 15 Plex log files
PlexDebugInfo-Tony__T-7.23-1076 (2021-09-28 17.12.04 -0400).zip (438.8 KB)
There are a bunch of errors in your log. My guess is that there are enough changes with iOS 15 that this just doesn’t work. This is going to take some work to it working.
Just got the latest iPadOS App
Attached are the log files from the failed downloads
PlexDebugInfo-Tony__T-7.24-1284 (2021-09-30 19.25.21 -0400).zip (858.6 KB)
Having similar problems on an iPhone 13 Pro running iOS 15.1 Beta 2. Hope there’s an update soon. Spent the day traveling by plane yesterday and discovered that my downloaded vids won’t play. Thanks for working on this!
:slight_smile:
So yeah, of course there’s no reply anymore.
And on top of that, the download doesn’t even check where I stopped watching an item. I have to manually find that spot. Absolutely awesome job Plex!
I am using the Download feature now, as on the tablet with Android, Sync was not working anymore.
When I want to download series episodes, no matter which quality I select, it will be always transcoded in 480p. Which is pretty pad for the hires display I have.
Only exception is ā€œOriginalā€ then the huge full file gets just downloaded.
Plex Media Server logs do not indicate something going wrong, it seems the Android Player (8.23.1.28053) is always trying to get only 480p transcoded.
