I created a little tool for syncing Rekordbox playlists over to Plex, so they can be listened to through Plexamp. It’s very nieche but figured why not share here.
Get it from GitHub - dvcrn/rekordbox-plexamp-sync: Sync Rekordbox playlists to Plexamp
This tool will dump your playlists from Rekordbox, then find the tracks within Plexamp and reconstruct the playlists in the same order. Intelligent Playlists aren’t supported (yet).
This is a very hacky early version and will likely only work on Mac hosts for now. I don’t have a windows machine to test on
You also need to have your Rekordbox library indexed with Plex, and disable all smart agents and content matchers on it. It currently needs the titles to be identical for better results. If they differ, it’ll try to use filename matching which didn’t have so great results in my tests.
becomes
