Sync "The Path Is Invalid"
I have two use cases where the status in the sync pane is “The Path Is Invalid”, both should be handled better.
  1. I have set up sync to include unwatched episodes of a season. For this particular show, I tend to delete the episodes as I watch them. In the Sync status it shows as “The Path Is Invalid” when the show is missing. The season is still ongoing, and there will be another episode that shows up eventually. Expected behaviour: I would like to continue to sync this series if it is still an active series.
  2. I have set up sync for a movie. After watching the movie on any client, I delete it. From this point onwards it shows in sync status as “The Path Is Invalid”. In this case I would like the delete to also remove the sync entry, or at least prompt me to delete the sync entry regardless of where it is deleted from.
