Hi all, I’m thinking of getting an iPad air 4 with USB type C. This means it can have an external drive plugged in. Can that be used to sync media from the plex server so that it can be used on the go or can you still only use the internal storage on the ipad?
I think you can change the sync location. I can with Android.
Attach the drive and check Plex Sync settings.
