Synology 1515+ PMS keeps stopping and can't access web
Server Version#: 1.141.5488-cc260c476
My PMS just stopped 2 nights ago. Cannot access the web from the synology or from PlexTV.
Installed the latest version, rebooted the NAS and the router.
Everytime I restart the PMS in the synology, it stops almost immediately.
I don’t know whether the logs are verbose or not, since I can’t access anything to adjust them.
Any advice to prevent me from uninstalling and rebuilding a huge library would be appreciated.
Thank you
com.plexapp.system.log (959.4 KB)
com.plexapp.agents.localmedia.log (340.6 KB)
com.plexapp.agents.localmedia.log.1.txt (1023.8 KB)
Logs.zip (7.0 MB)
Really appreciate you taking a look at this. I tried the database reset, but now it says the package won’t run.
Thank you for any advice you can give!
you are amazing! Didn’t have to fix the DSM. Thank you for both being incredibly fast in your response and accurate in your advice.
Take care.
