I had my PMs running fine on a synology DS918+. I had 2 units of 6TB in SHR (WBFS format). Yesterday system was restarted by a power failure. As soon as DSM restarted HDD1 started to launch I/O errors. I turned off NAS and removed this unit, rebooted and everything is working fine (With Volume 1 degradated, but fine) except Plex Media Server.
When I click on Launch, it seems to start but it stops in a couple of seconds.
I tried to unisntall PMS and reinstall it without removing DB (i don’t wan to loose the huge DB) and the problem persists…
Any idea what is happening?
NOte: The startup crash.log says:
Jun 17, 2022 09:32:15: Failed to initialize logging: Empty or non-existant file.
The last error from Plex Media Server.log is:
Jun 16, 2022 22:56:40.951 [0x7fdcf52a6b38] ERROR - Thread: Uncaught exception running async task which was spawned by thread 0x7fdcf3f8eb38: sqlite3_statement_backend::loadOne: database is locked
This last log doesn’t update more from a few minutes after this error.
Sorry you haven’t gotten any assistance… it seems this is a rather specific issue that’s most likely linked to the previous HDD failure and how DSM presents itself to Plex afterwards.
Beyond… the single-line of logs isn’t much to go with (except noticing there has been an error).
