Server Version#: -
Player Version#: -
Just a general question.
What Synology NAS can you suggest for Plex? I need HW Transcoding to provide 2-3 Streams at the same time.
Thanks in advance
Regards
Volker
Server Version#: -
Player Version#: -
Thanks in advance
Regards
Volker
Hi see the PLEX/ NAS compliance document
I have the Synology DS918+ and it’s working very well to me. i was able to get 2 streamings(transcode from 4k to 1080p) if you transcode to 720p you may be able to get 3 or 4. if you use direct play you can stream a lot. If you transcode from 1080p to 720p i was able to get more then 10 streams at the same time.
