Synology does not allow plex access
Server Version#: Synology DS414 DSM 6.2.3
Player Version#: Plex web version
I just installed plex on my Synology, where all my media files store, and when I launch it from my DS414, I always got the message:
No soup for you!
The server you’re trying to access doesn’t want to let you in. Make sure you’re signed in as a user with access to this server.
I attached the logs.zip here and hopefully someone will get me the solution. Many thx in advance.Logs.zip (1.8 MB)
You cannot install & setup PMS from a WAN IP address.
Your logs show a [24.189.X.X] address.
You must be on the same subnet (10.0.1.x) or SSH-tunneled into the unit.
Ok, I will try and get back to you. Many thx for the prompt reply.
It’s up and running now. Many thx again!
