Hello together,
recently I got a Synology DS 418 and installed the latest Plex Server Version 1.15.0.659-9311f93fd from this thread: Much faster (hopefully), smaller (mostly) and better PMS builds preview (1.15.0.573-123756e9a) . The installation worked and my video files are detected correctly. I am now trying to stream some of those videos, which are saved as .mkv files, to my Samsung TV (model: TV GQ75Q7FNG), but this only works to some extent. There are two problems I encounter and hope you can help me to understand the situation better.
Problem 1: Playback of some H.264 Videos lead to high CPU usage
When streaming some videos which are encoded with H.264 the CPU usage of my Synology NAS sykrockets to 99%, leading to severe lags und buffering pauses of the playback. I used the mkvinfo program to extract more information about the video stream and it seems to be dependant of the chosen h.264 profile. Here you can see the output of the mkvinfo program of two files which lead to the above mentioned high cpu usage:
Example 1:
| + Track
| + Track number: 1 (track ID for mkvmerge & mkvextract: 0)
| + Track UID: 4660655833373320124
| + Track type: video
| + Lacing flag: 0
| + Minimum cache: 1
| + Codec ID: V_MPEG4/ISO/AVC
| + Codec's private data: size 43 (h.264 profile: High 10 @L5.1)
| + Default duration: 00:00:00.041708333 (23.976 frames/fields per second for a video track)
| + Language: und
| + Video track
| + Pixel width: 1920
| + Pixel height: 1080
| + Display width: 1920
| + Display height: 1080
Example 2:
| + Track
| + Track UID: 18445989320895891896
| + Track type: video
| + Lacing flag: 0
| + Minimum cache: 1
| + Language: und
| + Video track
| + Pixel width: 1920
| + Codec's private data: size 44 (h.264 profile: High @L5.0)
The playback of other files works perfectly fine, the CPU usage is low and no lag or buffering pauses appear. Following is the mkvinfo output of videos which do not lead to high CPU usage:
Example1:
| + Track UID: 1
| + Track type: video
| + Lacing flag: 0
| + Minimum cache: 1
| + Codec's private data: size 43 (h.264 profile: High @L4.0)
| + Language: und
| + Video track
| + Pixel width: 1920
Example 2:
| + Track
| + Track number: 3 (track ID for mkvmerge & mkvextract: 2)
| + Track UID: 1
| + Track type: video
| + Lacing flag: 0
| + Minimum cache: 1
| + Codec's private data: size 46 (h.264 profile: High @L4.1)
| + Language: und
| + Video track
| + Pixel width: 1920
The main difference seems to be the used h.264 profile. My knowledge about this whole codec stuff is rather limited but it seems kinda weird to me as according to the following knowledge base article from Synology: https://www.synology.com/en-us/knowledgebase/DSM/tutorial/Multimedia/Can_my_Synology_NAS_transcode_4K_videos_for_my_device : “Any container or file extension in 4K 2160p (4096 x 2160) with codecs H.265 (HEVC), and in 1080p with codecs H.265 (HEVC), H.264 (AVC), MPEG-4 Part 2 (XVID, DIVX5), MPEG-2, and VC-1 can be transcoded up to 1080p by Synology NAS in 4K Group 3.” This text can be found under Note 4 and according to the same Knowledge Base Article the DS418 belong to 4K Group 3. No restriction is set about the used profile so I’m wondering why the playback leads to the high CPU usage.
Problem 2: Playback of video files with softcoded subtitles causes high CPU usage
The other problem I have stumbled upon lies in the use of subtitles. If I take a video file which itself plays without problems and activate a subtitle embedded into the file, for example .ass or .srt, the CPU usage rises to 99% and the video playback has buffering pauses every few seconds. This problem arises every time I use a softcoded subtitle.
If possible I would like to solve both problems allowing me to stream all my video files encoded with h.264 and use subtitles. Are there ways to achieve this? Or is the used hardware just not good enough to handle these use cases?
Thank you very much in advance for your answers and help. If you need further information please let me know I will provide them to the best of my knowledge.
Greetings,
xXKnightRiderXx
