Hello!
Is a Realtek RTD1619B CPU (Synology DS124) sufficient to run Plex Server?
Thank you.
Hello!
Thank you.
Only completely without transcoding.
Which means, all files must be prepared beforehand to be 100% compatible with the used client devices and the available bandwidth.
Thank you.
So playing only FLAC files to SONOS is no problem?
I couldn’t say. I have no experience with Sonos. Keep in mind that it requires working remote access to your server.
What do you mean by that?
Using Sonos requires the remote access (i.e. from outside your home network) to your Plex server to work.
Ah ok.
Did not realize that as mine has remote access and therefore is working.
Was asked by a friend to install it for him.
