Are there any guides on installing the Tautulli self signed cert on an Android device to allow the remote app to connect when HTTPS is enabled?
I have installed the cert through the, network settings -> install certificates menu in Android 8.1, but still get an SSL error (Untrusted/Unverified).
@eds89 - Browse to your external Tautulli address using Chrome. It should prompt for verification of your installed self-cert.
According to the last step at https://coderwall.com/p/wv6fpq/add-self-signed-ssl-certificate-to-android-for-browsing , once youâve done that, other apps should allow it (in theory, including Tautulli remote).
(Sorry, I use LetsEncrypt and have never had to use self-signed to know if that would work)
@JamminR Unfortunately there is no change here.
I have tried adding the cert using both DER encoded and base64 encoded CRT files, have browsed to the site in Chrome on the device, but the Tautulli app still gives me the same certificate error.
Is there a way to get email/twitter alerts that have the actual thumbnail of the episode I just watched? Iâve tried several different tags to try and get the right image, but all I get is the poster for the overall season of the show Iâm watching, not the thumbnail of the actual episode.
Is this possible? Or not? If so, what is the tag I need to use to get the show image?
In the Tautulli beta (v2.1.0-beta (2018-04-07)) how do you specify to use self hosted images with notifications? Iâve been having problems with images in emails (they just donât come through at all), I figured this might fix that problem.
@JamminR I have managed to successfully install the root CA cert for my new internal Active Directory CA, so I am going to try adding my wildcard cert to Tautulli, and see if that solves the problem.
Iâve always used LetsEncrypt, âit just worksâ.
@blinddark said:
can you say, what you have written in the condition Logic feeld?
Username
is
Myuser
If you only have one condition, you donât need condition logic. You should be using âis notâ.
If you donât want to receive notifications for yourself for any agent, youâd do like the following.
Demonstrated in the Tautulli wiki - GitHub - Tautulli/Tautulli-Wiki: Wiki for Tautulli
Should be possible using {thumb} - if itâs not working, itâs possible Plex doesnât have the episode image yet?
{thumb} The Plex thumbnail for the movie or episode.
{parent_thumb} The Plex thumbnail for the season or album.
@JamminR I have tried {thumb} and I just get the cover image for the season of the TV show I have. If I go into the season, it shows me each episode with a separate thumbnail image.
@âsethjk@gmail.comâ said:
Is it possible to install on WD MYCloud Pro?
Maybe?
Looks like some 3rd party folks have packaged it. Youâll likely need to ask THEM for help in getting it running.
Once you have it running, this is the place to discuss itâs use.
@SteveG144 said: @JamminR I have tried {thumb} and I just get the cover image for the season of the TV show I have. If I go into the season, it shows me each episode with a separate thumbnail image.
Sorry then. Itâs possible that tag is whatâs being passed to Tautulli from Plex.
Or, possibly, and I wouldnât know a way to confirm, itâs a bug in Tautulli.
@JonnyWong16 or other dev - when using {thumb}, SteveG144 is getting the show season picture instead of the episode picture as described in the tag descriptions (ie, thumb_parent I think would be season pic)
Plex bug, or Tautulli bug? (or badly described parameter descriptions?)
Thank you for the update to Cloudinary for the newsletter. This works much better now.
I still have one wish for the newsletter.
Currently, it simply combines all film and series libraries. I would like to separate this. That is, if I have 2 libraries for series, they will be displayed separately. Say series Complete and series running or Top 50 films and new on cinema. Users would immediately know which library to look in.
For example, he would also separate documentaries and feature films, since I have separated them, etc. The overview for the users would definitely increase this.
Thanks for your great work and keep up the good work.
If Iâm interpreting your request correctly, you can accomplish this by selecting which library you want for a newsletter in the Newsletter Agent settings, Configuration tab. Just set up multiple newsletters, each using the set of libraries you want.
Just a quick question - is there any development for facebook notification plugin? I see it requires publish_actions permission, which is being deprecated, so any new app will not have it anymoreâŠ
