Tautulli - Monitor your Plex Media Server
@quhectic24 said:
@JonnyWong16 said:
@spsanderson said:
I am having trouble connecting Gmail I get an error in the log that says I need to run connect() first…any ideas
@quhectic24 said:
I just updated and I am having a weird issue where I am not receiving any notifications. They are not failing since there are no fails in the logs however, I am able to send test notifications to facebook and pushbullet. Anyone experiencing similar issues or have a fix?
No logs = No help.
No errors in the notification logs but here are the Tautulli logs after recently adding a movie…
2018-03-11 23:38:19
ERROR
Tautulli NotificationHandler :: Notification thread exception: No JSON object could be decoded
Traceback (most recent call last):
File “C:\PlexPy\plexpy
otification_handler.py”, line 56, in process_queue
add_notifier_each(**params)
otification_handler.py”, line 112, in add_notifier_each
if manual_trigger or notify_custom_conditions(notifier_id=notifier[‘id’], parameters=parameters):
otification_handler.py”, line 211, in notify_custom_conditions
custom_conditions = json.loads(notifier_config[‘custom_conditions’]) or
File “C:\Python27\lib\json_init_.py”, line 338, in loads
return _default_decoder.decode(s)
File “C:\Python27\lib\json\decoder.py”, line 366, in decode
obj, end = self.raw_decode(s, idx=w(s, 0).end())
File “C:\Python27\lib\json\decoder.py”, line 384, in raw_decode
raise ValueError(“No JSON object could be decoded”)
ValueError: No JSON object could be decoded
2018-03-11 23:38:19
DEBUG
Tautulli ActivityHandler :: Session 13 resumed.
2018-03-11 23:37:11
DEBUG
Added 1 items to the recently_added database table.
2018-03-11 23:37:11
ERROR
custom_conditions = json.loads(notifier_config[‘custom_conditions’]) or []
File "C:\Python27\lib\json_init
.py", line 338, in loads
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
2018-03-11 23:37:11
DEBUG
Tautulli TimelineHandler :: Library item 467676 added to Plex.
2018-03-11 23:36:50
DEBUG
Tautulli TimelineHandler :: Library item ‘Hellraiser: Deader’ (467676) done processing metadata.
2018-03-11 23:36:11
DEBUG
Tautulli TimelineHandler :: Library item ‘Hellraiser 7 Deader’ (467676) added to recently added queue.
Try toggling around the custom notification conditions. Maybe add a random condition. Save the notification agent settings, remove the condition, and save again.
If that doesn’t work, just delete it and add a new notification agent (or duplicating it might work).
@JonnyWong16 said:
Post logs to gist please.
Was late getting back to this and saw you had released the master branch. Converted to that and it’s working like a charm now, all functions back to normal.
Just made a $25 donation via PayPal for all your work and support on it. Really dig the 2.0 upgrades and layouts!
Ross
@SwiftPanda16 said:
@quhectic24 said:
@SwiftPanda16 said:
No logs = No help.
2018-03-11 23:38:19
ERROR
2018-03-11 23:38:19
DEBUG
2018-03-11 23:37:11
DEBUG
2018-03-11 23:37:11
ERROR
2018-03-11 23:37:11
DEBUG
2018-03-11 23:36:50
DEBUG
2018-03-11 23:36:11
DEBUG
Tried all of the above but still the same issue. I do notice that I am getting pushbullet “watched” notifications and the logs say browser notifications are working. Nothing for facebook at all. Was working minutes before I updated from Plexpy…
@quhectic24 said:
@JonnyWong16 said:
@quhectic24 said:
@JonnyWong16 said:
No logs = No help.
2018-03-11 23:38:19
ERROR
2018-03-11 23:38:19
DEBUG
2018-03-11 23:37:11
DEBUG
2018-03-11 23:37:11
ERROR
2018-03-11 23:37:11
DEBUG
2018-03-11 23:36:50
DEBUG
2018-03-11 23:36:11
DEBUG
Did you delete it and add it again?
@SwiftPanda16 said:
@quhectic24 said:
@SwiftPanda16 said:
@quhectic24 said:
@SwiftPanda16 said:
No logs = No help.
2018-03-11 23:38:19
ERROR
2018-03-11 23:38:19
DEBUG
2018-03-11 23:37:11
DEBUG
2018-03-11 23:37:11
ERROR
2018-03-11 23:37:11
DEBUG
2018-03-11 23:36:50
DEBUG
2018-03-11 23:36:11
DEBUG
Tried duplicating first then re-added from scratch and deleted the originals..
Same issue. Added from scratch, but issue still persists
This only happens with “Recently added” . . The rest of the triggers work.
@SwiftPanda16 said:
@Intruder71 @dennis.ayala
No logs = No help.
GitHub - Tautulli/Tautulli-Wiki: Wiki for Tautulli
@AgentMax
Try deleting that notification agent and recreating it.
JonnyWong16:
Since stats were so srewed up, I erased the tautulli.db and restared the application so it creates a new file. It was working fine for some hours but it started to repeat the same lines on some of the entries. For what I can see, it might have something to do when the user’s stream is paused for prolonged periods of time.
I uploaded the most recent tautulli.log to my original post and to this one.
Regards,
Dennis
@“dennis.ayala” said:
No logs = No help.
@AgentMax
JonnyWong16:
Regards,
Dennis
Not the correct way to post logs.
@SwiftPanda16 said:
@quhectic24 said:
@SwiftPanda16 said:
@quhectic24 said:
@SwiftPanda16 said:
No logs = No help.
2018-03-11 23:38:19
ERROR
2018-03-11 23:38:19
DEBUG
2018-03-11 23:37:11
DEBUG
2018-03-11 23:37:11
ERROR
2018-03-11 23:37:11
DEBUG
2018-03-11 23:36:50
DEBUG
2018-03-11 23:36:11
DEBUG
After some more toggling of the settings and a complete reboot of the server, I was able to get everything working. Thanks for the very fast responses. This is truly a great tool. Thank you!
@JamminR said:
@rbeatse said:
So, is ther a way to get my history back if I still have the old folder structure?
(Replace ‘tautulli.filetype’ with ‘plexpy.filetype’
Thanks. I stopped Tautulli and copied out the tautulli.db file and then moved the plexpy.db file in and renamed it to tautulli.db and the I couldn’t get tautulli to restart. After trying a few things, I still couldn’t get it. Is there a way to merge the plexpy.db (I have a year or so of history there) with the tautulli.db that I have 30 days or so of history?
With Tautulli, has disabling of user notifications gone?
In PlexPy it was > Users > Edit mode > Toggle notifications (bell icon). I would like to disable notifications for my own viewing.
I created a condition in the new Notification Agent settings: ‘Username’ does-not-equal [my user name]
@JonnyWong16 - Yes. I know where feature requests go, as has been my answer to others in hoping to help here. :tongue:
I wasn’t asking so much that it be added (yet), as to what/if any, thought process had ever been contemplated about it if any.
If I suggest it as a feature, I feel it could be used as a basis for 2-3 of your top requests. I feel part of the challenge of the top requests are that I think they are slanted towards, or at least, statistics more easily obtainable, on *nix systems out of the box. Where as Windows might require additional libraries. Just thinking aloud here.
That, and of course, I have my own idea for my first module for it that I’d love to share with the community if I were successful in learning conversion of my PHP code to Python.
Merge? No. Tautulli uses a different table setup.
I ran PlexPy and Tautulli concurrently, but, Tautulli converted my “copied from old PlexPy folder” plexpy.db and config.ini after I copied them into my newly created tautulli folder when I first started Tautulli beta up some months ago, so, the data from previous years was already there in Tautulli.
Have you tried leaving the name of your plexpy.db as, literally, plexpy.db?
Perhaps Tautulli sees that it’s “plexpy.db” and goes “oh, i need to convert this”.
I’d ensure backup/move of the ‘new/past month’ Tautulli.db file first (and that Tautulli was shut down first too)
You’d lose the past month of Tautulli, but it’s worth a shot.
THEN you might be able to find a way to get old plus new using an SQLite manager or something. I figure merging two of the same/similar, using date as determination of where the entries get input, ignoring duplicates, would be easier than two totally different db.
https://gist.github.com/PureSkillz/2b36c1be8809fb14986ba509f5f64eb8
You have multiple instances of Tautulli running. Check your python processes.
**EDIT: I think this post acted as a rubber duck. I found and enabled Include Rich Metadata Info on the Notification Agent’s Configuration tab, retested, and successfully had the preview. **
I’ve added a Facebook notification for Recently Added and have included the IMDB/TVDB urls, but the Facebook post does not generate the preview. It’s posting all of the information as I would expect, and was working on PlexPy prior to upgrade to the latest Tautulli release.
Here is the Body Text from the Notification Logs screen (action = on_created):
Westworld - Trompe L'Oeil - S01E07 was recently added to Plex.
https://thetvdb.com/?tab=series&id=296762
Here is the Body Text from the Notification configuration:
{title} <episode> - S{season_num00}E{episode_num00}</episode> was recently added to Plex.
<movie>{imdb_url}</movie><episode>{thetvdb_url}</episode>
What are the recommendations for movie/season URL previews in Facebook?
Also - this tool is a wonderful addition to Plex. Thank you for all the work you’ve done.
I used to have great setup for FB notifications with PlexiPy - only movie libraries selected to be used with notifications (we used to be able to select them via libraries) now there seems to be no option? after new update im getting ALL notifications including single TV episode notifications … (A LOT OF THEM) How can we only select specific libraries for notifications please? Thanks
Also same issue as above (no URL to imdb is being added to FB notifications) it used to work before the upgrade, thanks.
@tarnecki
notifications for libraries have been moved to notifications, see below:
(I did not want notifications when someone played a song but i do want them for movies and tv shows, so I put all my music lib in and then in the bottom i “anded” together the three conditions that applied to my music lib.) Not as simple as the old way but much more powerful. this allows me to get notification from my movie and tv lib but not my music lib.
