if you had read my post correctly i suggested he must of posted there just before i made my post here. issue was resolved.
Hi there. My push notifications used to work fine, but recently theyāve mainly stopped working. I get some push notifications but not others, randomly. If I run a test notification from the web page I get an error:
Tautulli Notifiers :: Request response: Error sending message. Invalid payload: {āactionā:"{action}",āserverMachineIdā:"{server_machine_id}",āserverNameā:"{server_name}",āscriptā:āwebhookā}
And if I run a notification test from my phone, I get a different error:
Tautulli Notifiers :: Request raised a HTTP error: [400] Bad Request (local client error).
Iāve uploaded all my logs here:
Any ideas?
Cheers
Jamie
was just on the install page and iām not seeing instructions for manjaro. i know itās in the repositories but doesnāt seem to install correctly from there. does anyone have proper instructions for manjaro, cause the below is all i see on the instructions page. thanks
Tautulli will be installed to
/opt/Tautulli.
- Open a terminal
- Install Git
- Ubuntu/Debian:
sudo apt-get install git-core - Fedora:
sudo yum install git
- Ubuntu/Debian:
- Install prerequisites:
- Ubuntu/Debian:
sudo apt-get install python python-setuptools tzdata - Fedora:
sudo yum install python python2-setuptools
- Ubuntu/Debian:
- Type:
cd /opt - Type:
sudo git clone https://github.com/Tautulli/Tautulli.git - Optional:
- Ubuntu/Debian:
sudo addgroup tautulli && sudo adduser --system --no-create-home tautulli --ingroup tautulli - CentOS/Fedora:
sudo adduser --system --no-create-home tautulli sudo chown tautulli:tautulli -R /opt/Tautulli
- Ubuntu/Debian:
- Type:
cd Tautulli - Type:
python Tautulli.pyto start Tautulli - Tautulli will be loaded in your browser or listening on http://localhost:8181
- To run Tautulli in the background on startup, refer to Install as a daemonote
We donāt provide support for the iOS app. You need to contact the app developer.
i would like to automate the launching and running of tautulli. iād like to know if i can create a link to tautulli and simply have it do everything in the background including launching the browser and going opening tautulliās local host? thanks
Psst⦠check the FAQ. LOTS of answers there to questions asked hundreds of times.
Especially this link from the faq page āInstalling as a Deamonā (in techno-babble, simpllfied, deamon means ārun in backgroundā)
Psstā¦not what i had in mind. suggestion next time just attempt to answer the question without the smartass comment.
iām not looking to have tautulli running constantly. i just want to create a link to automate launching the pyhon2 tuatulli.py in console, and then actually open the browser and open taurulli.
I donāt remember linux āshortcutsā, but in Windows, Tautulli already does what you ask by default. I donāt see why creating the linux equivalent wouldnāt do what you ask.
Windows users double-click tautulli.py (or a shortcut to it), and Python terminal opens, starts tautulli, and if Tautulliās option under āWeb interfaceā called āopen brower at startupā is checked, it opens.
Many Windows users change the shortcut to open pythonw.exe instead of python.exe, so that the terminal window doesnāt open.
no in at least manjaro clicking the Tautulli.py file doesnāt do anything. opening konsole in tautulliās folder, using sudo su entering password, entering python2 Tautulli.py is the only way i see to launch it at this point.
If I remember, youāll need to make some type of script file that runs that exact terminal command.
I think they end in .sh, at least in my fuzzy memory.
Have fun learning linux.
youāre just replying to to increase your post count, DON"T. plex doesnāt give out bonus points for the number of post you have.
Wow. I donāt think Iāve ever seen anyone on these forums that I have less inclination to help than gRaVe-dIGgEr. Have fun with your problem, salty.
Iām purposely ignoring him.
I only check Tautulli infrequently (itās just me, no users), but the last few times I have checked over the past few weeks, it shows all my libraries and media, but it shows no activity, which is certainly false. In the past week or so Iāve played media from work through Plex Web, and from home through Plex Web, Roku, and Android TV.
Iām not sure what troubleshooting steps there might be. Where do I start?
Plex Server: 1.18.4.2171
Plex Web: 4.18.1
Plex Android TV (Shield): 7.26.0.14578
Plex Roku: 6.4.9.6153
Plex Media Server Logs_2019-12-21_09-26-57.zip (3.0 MB)
And, now, so will I.
At least in trying to assist someone else, I re-learned more about linux automation that Iād long since forgotten. I was also reminded some people just canāt be helped, even with great big signs offering clues āThis is the way ------>ā
Can I be of assistance here?
I run Plex and Tautulli on Win10. Prior to the latest Tautulli update, I had the GeoLite2 database showing up in the settings under āTautulli Configurationā. Now it shows at the very bottom in the āTautulli Scheduled Tasksā section, but it shows the state as Inactive. I looked through the wiki and the installation instructions, but did not find any information to activate that task. Are there instructions to do this anywhere?
Under settings you need to click on 3rd Party APIs. There is then a link to here: https://github.com/Tautulli/Tautulli-Wiki/wiki/3rd-Party-APIs-Guide to explain getting it setup.
-Shark2k
That did it. Thanks for pointing me there!
