TCL 6 Roku Plex App Crashing w/ Direct Play + Allow DTS-HD
Bump any updates? This is still an issue with
Plex Server Version 1.22.2.4282
Plex for Roku Version 6.7.21.7002
Roku Version 10.0.0.4165
Same Behavior
Plex Server Version 1.23.3.4706
Plex for Roku Version 6.8.3.7132
Roku Version 10.0.0.4197
The behavior has changed for the better. Now instead of crashing at 99%, a DTS MA file will transcode to DD AC3 640kbps. This is a welcome improvement but still not the desired result.
Hi, I also have a TCL 65R635-CA that was playing all files flawlessly up until a couple days ago. It still plays 720p fine, but the 1080p files only get to 13-33% before the app closes back to the home screen. All the other apps like Netflix, Prime, Disney… still work. The tv is hooked up to a Yamaha RX-V485 through eArc. I don’t believe that I’ve changed any settings anywhere from when it was working.
I have another TCL tv that’s Android, and an LG set using its own system, and the Plex apps on both of those play the 1080p movies with no problems; same with the app on my PC.
Plex Server: 1.24.0.4930
Plex for Roku: 6.8.8.7198
The Plex Server is on my PC, and the files are on a Drobo NAS.
Any thoughts that haven’t already been offered?
Bump Still An issue. It seems the default behavior at this point is to convert to DD the first time or two but then the old 99 percent then crash happens.
Roku 10.0.0 Build 4209
PMS 1.24.2.4973
Plex app 6.9.4.7254
Ooooohhhh man. things are happening now. I can confirm this is now working with most if not all DTS MA 5.1 tracks. Unfortunately any file I attempt to play that is DTS MA 7.1 defaults to AC3 640kbps. Plex Dash shows direct play of DTS MA 5.1, while the receiver shows DTS. Almost there, just gotta get 7.1 working and I’ll be soooooo happy. Keep up the good work.
Plex app : 6.9.5.7308
PMS : 1.24.3.5033
Edit: So after listening I’m guessing only the lossy DTS core is making it to the reciever. Sounds pretty bad compared to the same file playing with DTS MA showing on the reciever.
Still not working
Roku 10.5.0 Build 4201-88
PMS 1.25.1.5286
Plex app 6.9.14.7448
