Terrible Plexamp audio quality on Pixel devices
I have a Pixel 3 and all of my music playback on the new Plexamp app sounds very tinny with little to no bass and much quieter when compared to the regular Plex app. I am running the latest 3.0.3 but this issue has persisted since the first release. I don’t notice the issue much during Bluetooth playback strangely.
There is a Reddit post of other users having the same problem mostly with Pixel devices.
I have tried basically every combination of settings in the app and nothing has sounded different. I’ve reinstalled 3 times, cleared app cache and data, restarted my phone. Nothing has helped.
Would love you to look into this. Thanks!
I know you said you tried all combinations of settings, but have your tried TURNING OFF Loudness leveling? Once you do this… clear cache and play something.
Didn’t do anything for me :frowning:
Thanks for the recommendation
Is your music being transcoded to a very low bitrate?
All my lossless music “direct play” showing FLAC & 44.1kHz.
All my mp3s show 320kbps.
Doesn’t look like any transcoding to me
do you have limiter OFF?
do you have preamp too above 0 dB?
do you have equalizer OFF?
do you have loudness leveling ON/OFF?
Turned limiter OFF (was ON)
Turned preamp to 0 dB (was +4 dB)
Checked that equalizer is OFF
Turned loudness leveling OFF (was ON)
Maybe got a little louder (hard to tell), but still sounds nowhere near Plex app quality. Much quieter and still little to no bass.
hmmm ok… i should’ve said my preamp is +4dB for reference.
i just played with these settings and compared to normal Plex… definitely a difference with some of these turned on.
trying turning the preamp back up to +4dB… maybe they knew something and set that as the default.
Can I ask what type of device you’re trying this on? It seems to be only affecting certain models of phones. Works flawlessly on Windows, Linux, and Android over Bluetooth for me, just my phone’s internal speakers are the problem
Samsung S7 running android 8.0… there have been a few issues i’ve encountered that might be related to samsung as well.
Still running into this issue on Plexamp 3.1 despite the number of audio-related fixes they made
