The Android mobile client is stuck
Server Version#: 1.40.4.8679
Player Version#:10.19.0.1142
When using the Android Plex client, the entry page has been stuck in the Plex opening screen animation page, in the case of the same network and the same server, iOS has no such problem, the user is currently located in China, and the client version and server version have been updated to the latest
+1
大概率是被阻断了
will plex offical do something to solve the problem?
But the Plex media server on the NAS works fine, the same goes for the windows player and the ios side player, they are both in China, using the same network, only Andriod Player has this problem, I guess the problem is due to some link servers to overseas servers like Facebook or X, andriod player try to link these server when user open the andriod player but keeps failing ,so please help us solve the problem
可以在android app内添加自定义URL远程连接,而不是去plex.tv获取我的服务器地址解决这个问题?
Hello,
Where Can I activate plex for android? I have found how to buy plex pass only. But I want to pay app in play store.
regards.
安卓的app添加自定义url远程连接,我看到只能输入数字ip,对于没有固定ip的还是无法解决啊
sorry,I have got the plex pass on the web firstly ,so i don‘t know how to pay app in play store,i suggest you can pay on the website。
The Play Store is the app that usually comes preinstalled on Android devices. It allows you to select and install all the Android apps. It is operated by Google.
There is another app store operated by Amazon, which comes preinstalled on Amazon Android devices (“Kindle”).
The Plex mobile app is available in these two stores and can be unlocked in there. If your device has none of these two app stores, you cannot buy the one-time app unlocking.
