The 'Delete Episodes After Watching' setting keeps randomly resetting
So most of the shows I DVR I choose to keep even after I watch them. However, there are a few that I have setup and tell Plex to delete 1 day after I watch it.
However, these shows seem to randomly reset this option to the ‘Never’ setting. I’ve changed these back at least a dozen times, but again it seems random. One of the three from this week was set how it should be, while the other two had to be changed back to delete after one day.
Last week I had to do the same to a couple of them. Is there any reason why this keeps happening?
Do you have the same setting set on the show in the library. You can check under Edit Show --> Advanced :slight_smile:
